May 26, 2017, 07:36 |
mechanical input file for porous domain
Rep Power: 9 |
Hello everyone.
My model contains multi-component porous domain. And solver can't start running because CFX-Pre says 'Multiple solid definitions are not supported'. I need to create mechanical input file,right? How do i create one? Can you guys give me an example? |
May 27, 2017, 05:16 |
Rep Power: 143 |
Please post an image of what you are doing and your CCL.
May 27, 2017, 07:40 |
Rep Power: 9 |
that's it i do not have ccl photo because the solver crashes with exit code 2 and 'Null pointer to m_geom' error |
May 27, 2017, 10:51 |
Rep Power: 32 |
You are setting up the case incorrectly.
Please review the Reacting Flow tutorial to learn how to setup a multicomponent flow. Once familiar with it, review the Catalytic Converter tutorial to learn how to setup a porous solid domain. You have setup the case as multiphase instead of multicomponent, and it is true ANSYS CFX only supports one "solid phase" per domain. It supports multiple "fluid phases" per domain, where a "fluid phase" may be a "multi-component mixture". Hope the above helps, |
May 29, 2017, 12:23 |
Rep Power: 9 |
thx for you reply,helped me a little bit, but i didn't really find how to create multi-component POROUS domain. am i missing it?
May 29, 2017, 12:30 |
Rep Power: 9 |
wait, should i just create new solid material with fixed composite mixture?
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
