June 13, 2017, 10:31 |
Nu in CFX
Ali karimi
Rep Power: 9 |
hey guys!
I wanna simulate a heat exchanger with internal and external flow, water flows inside pipe and air outside of it. my problem is I don't know how to calculate Nu number. My reference paper used functions that attached for calculating Nu number please someone help how to calculate Nu in CFX.
Life is fluid... |
June 13, 2017, 12:18 |
Rep Power: 32 |
Your question is very general.
Which type of Nu number are you interested in ? What is the purpose/goal of computing the Nu number at all ? There are several variants of the Nu number, and each has a different formula. Are you interested in the local Nu number or the mean/average Nu to compute total heat transfer rates ? For example, an energy balance for inner flow implies (neglecting kinetic energy for now) Q_wall = Mass Flow * (Static Enthalpy_outlet - Static Enthalpy_inlet) For an average Heat Transfer Coefficient HTC_average * Area Pipes * Appropriate_Delta_T = Q_wall Then, Nu_average = Q_wall * Diameter/ (Area Pipes * Appropriate_Delta_T) Still unanswered questions; therefore, more information specific to your setup is required. Summary: it is not trivial to answer w/o specifics. Hope the above helps somehow |
June 13, 2017, 13:48 |
#3 | |
Ali karimi
Rep Power: 9 |
So I should enable HTC in expert parameters , my inlet temp is 40c , what value should I set for reference temp in HTC? IMG_20170613_190649.jpg Sent from my SM-N920C using CFD Online Forum mobile app
Life is fluid... |
June 13, 2017, 16:16 |
Erik
Rep Power: 23 |
Check the FAQs
https://www.cfd-online.com/Wiki/Ansy...ficient_in_CFX |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 02:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
