Merge Manually Created Blocks with extruded Face Blocks |
November 12, 2019, 09:39 |
Rep Power: 6 |
Hello everybody,
I have the following issue: - I want to hex mesh a volute. As it has difficult geometry I created the blocks a follows by hand: Via the edit Mesh tab --> Create Elements, I created manually hex elements (by choosing points) where the geometry is difficult. Then via File --> Blocking-->Create from Unstruct Mesh I got my blocks. - When I now want to create a block via extrude Face in the blocking tab, the blocks have a different color then the ones from the manual approach and a strange mesh occurs at each interface of an extruded Faceblock. -When I want to merge for a example two blocks (one created via extrude Face and the other created from the unstructured mesh) it says: Merge Region contains more than one material. Does anybody know where the problem is? Thanks a lot for your help! |
November 12, 2019, 16:45 |
Rep Power: 143 |
This sounds like basic ICEM questions. You should do the ICEM tutorials to learn the basics of this software.
Also be aware that ANSYS has a software package called Turbogrid specifically designed to generate high quality meshes on turbo machines. You might find that a better meshing application for your case.
November 13, 2019, 00:54 |
Rep Power: 6 |
Thanks Mr. Horrocks for your answer.
I have solved the problem. The problem was that the manually created blocks were added to a different part then the one I extruded. Have a nice day! |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
