Edit surface in Build 5.5
Old   May 2, 2002, 05:42
Default Edit surface in Build 5.5
Bogesz
In CFX-Build 5.5 often have to use Edit/surface/edge match. If I look on my geometry with the "smooth shaded" button turned on, after that kind of editing the geometry looks sometimes very distorted. Is this just a visulaizing mistake of Build or does this step relly modify the geometry? (especially in my model i have truncated cones)
Thx Bogdan
Old   May 2, 2002, 09:15
Default Re: Edit surface in Build 5.5
Robin
Hi Bogdan,
This is just a vizualisation thing.
All the edge match method really does is add a vertex to the edge of a surface to match vertices on a connecting surface, thus creating a trimmed surface (default color magenta). The underlying surface definition is still the same and can be recovered by using Edit>Surface>Dissassemble
Robin
Thermocapillary free surface flow zakifoam OpenFOAM Running, Solving & CFD 10 December 12, 2016 11:44
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Different surface incident radiation between surface and surface-shadow Cortomaltese FLUENT 0 July 16, 2011 07:00
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 12:19
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 06:27
