July 6, 2017, 21:12 |
Very Strange Error:GET_PRESIP_ZIF_CDEN
Shuai Wang
Rep Power: 8 |
After the simulation finished, the solver didnt loaded the results. The error is this:
ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine GET_PRESIP_ZIF_CDEN whether the data is not read into the solver or the calling of procedure transfering data has a problem? Anyone knows how to do this?? |
July 7, 2017, 02:37 |
Maxim
Rep Power: 12 |
You mean this error message is displayed by CFX Post? The Solver is calculating the simulation, and after it is finished, you don't need to open your project in Solver any more?
Is it a pop-up window in Post? Can you load other projects in Post (= do you get that message only for this simulation or do you get a problem every time you open Post?) |
July 7, 2017, 05:46 |
#3 | |
Shuai Wang
Rep Power: 8 |
Then you're right, -Maxim-.When I set up eyerything in CFX-Pre and then start runing,the CFX Post give me a error every time.In fact,it doesnot get into the loop to calculate . |
July 7, 2017, 06:12 |
Maxim
Rep Power: 12 |
post the ccl and out file. We might find an error. Pictures of your setup would help too
July 7, 2017, 06:17 |
Shuai Wang
Rep Power: 8 |
July 10, 2017, 08:36 |
Rep Power: 16 |
It's not a CFD-Post error, it's a CFX-Solver error. Either the error happened during the calculation, or it happened at the end when trying to write a results file.
The most useful file to post would be the output (.out) file for the run, as this contains the CCL and the solver output. CG |
July 10, 2017, 08:50 |
#7 | |
Shuai Wang
Rep Power: 8 |
You mean that I should make the output (.out) file as initial file,then start running.Don't you think so? |
July 10, 2017, 08:57 |
Maxim
Rep Power: 12 |
no, he meant that you should upload the *.out file from your failed run here. That's also what I asked before and you ignored...
July 10, 2017, 09:08 |
#9 |
Shuai Wang
Rep Power: 8 |
July 10, 2017, 09:40 |
#10 |
Maxim
Rep Power: 12 |
well, I don't know how we are supposed to help you if you won't provide the data we are asking for. So please upload the *.out-file because the error you posted was probably only part of the complete error message.
[mesh manipulation] Strange results after using refineMesh on radial 2D-Mesh | Zarchias | OpenFOAM Meshing & Mesh Conversion | 1 | October 30, 2018 10:57 |
[blockMesh] Strange non-hexahedral cells? | maka15 | OpenFOAM Meshing & Mesh Conversion | 3 | May 19, 2016 08:56 |
[surface handling] surfaceFeatureExtract strange behavior | wc34071209 | OpenFOAM Meshing & Mesh Conversion | 0 | March 11, 2014 09:22 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 14:40 |
Strange Problem With updating the library | farhagim | OpenFOAM | 0 | August 10, 2010 12:34 |
