July 5, 2002, 06:37 |
Parallel solver problemes
Hi
I got a problem with the solver on my win nt computer. When I have started a job using 2 processors on my dual cpu computer, the job finishes but it takes forever before the final sync. point and the .res file has been written. I start the job from within the gui. Why does it do that ? Any hints. Regards Jens |
July 5, 2002, 08:58 |
Re: Parallel solver problemes
It depends on your problem size.
I work with a dual PC running on NT and CFX-5.5 takes about a minute or two to do this final syncronization. My mesh has almost 500k elements. How long it takes to you? Regards, cfd guy |
July 5, 2002, 15:46 |
Hi
More than 20 minuttes. /Jens |
July 8, 2002, 20:18 |
Does your problem have a lot of CAD surfaces? If so then this could be part of the problem. Solution data is written to the results file for every CAD surface and this can take quite a bit of time to write out the results.
Neale |
July 9, 2002, 09:12 |
I've experienced the same problem, where our run took almost an hour and a half to close down, running on 2 single processor 1.5Ghz machines under win2000. Our mesh was about 1,000,000 elements but we had between 5-10,000 surfaces in the model. Does anyone know of a work around for this or if the guys at CFX are working on this problem ? We find that it soon can eat up into any of the time savings achieved running a job in parallel when it takes so long to start and stop. Would i get a better speed up if I ran under Linux rather than Win2000 ?? Bob
July 11, 2002, 10:50 |
This problem is NT/W2k specific so running on Linux should resolve the problem. The guys at CFX are aware of the problem and working on it.
periodic condition at parallel solver | Amer Mahmood | FLUENT | 3 | October 28, 2019 08:34 |
Events and Parallel Solver | Duarte Albuquerque | Siemens | 4 | July 20, 2008 14:46 |
Parallel solver, divergence | Phil | FLUENT | 0 | April 30, 2008 09:42 |
UDF problem with Parallel Solver | manu | FLUENT | 0 | January 24, 2008 14:31 |
Which parallel solver is most suitable for my app? | zonexo | Main CFD Forum | 1 | November 17, 2006 09:46 |
