laufrad2883
Rep Power: 10 ![]() |
Hi all,
I am simulating a radial fan with a spiral volute. Everything goes well, but I am not able to initialize all components in Post using the turbo mode. I tried to define the regions manuelly by clicking "edit" on the "rotor component" but in the end there is an error with the rotation axis or not set regions. Other than that, for the "stator component", since I am having a spiral volute, I do not have any hub or shroud or blade. After leaving the options blank, I have got the same error as before. Can anyone tell me any solutions to solve this? thanks! |
jiaji lu
Rep Power: 9 ![]() |
I also met same problem. Have you solved the issue? Some suggestions on the forum is uncheck volute but only initialize the rotor part.
Display Modes | |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
Accessing velocity components and gradient of velcoity components | vivekgnhtr | OpenFOAM Programming & Development | 3 | June 27, 2022 03:39 |
Question on the sequence of grad(U) components | ripperjack | OpenFOAM Post-Processing | 1 | September 18, 2018 13:19 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
volute geometry definition | Derrik Mazzer | CFX | 2 | May 15, 2001 09:20 |
