October 17, 2017, 15:21 |
Error in parallel run
Daniel Lira
Rep Power: 10 |
Hi everyone,
I know this is a common problem here, but I haven't been able to see a solution for this in the forum. I'm getting a non-existent Partitioner executable error when running simulations in parallel, it happens both when I try to run it distributed (in cluster) or even local, but serial works fine. I'm using Ansys 15.0 and have a license. |
October 17, 2017, 18:03 |
Rep Power: 143 |
Check that your installation is complete and the paths have not been mucked up. Maybe remove ANSYS and re-install it. Also, if you run old versions of ANSYS on new OS then weird things can happen - it might be time to consider upgrading to the current version.
October 17, 2017, 23:25 |
Rep Power: 11 |
Did you try both Intel and Platform MPI?
October 18, 2017, 08:50 |
Daniel Lira
Rep Power: 10 |
Hello ghorrocks and Christophe, thanks for your replies.
I’ve already tried to reinstall the software a few times, I’ve even formatted the computer. And yes, I’ve tried all parallel options, the only one that works fine is serial. |
October 18, 2017, 17:25 |
Rep Power: 143 |
You can be sure it installs correctly and works for time for just about everybody. So if that is not working then there is something unusual with your setup. You are going to have hunt around to find it.
October 21, 2017, 09:56 |
Rep Power: 11 |
I've had parallel problems on old versions of ANSYS, similar to v15/16. This was caused by certain lines of code in the startmethods.ccl file, which I ended up deleting. CFX would freeze up at the solution part and not the partitioner like yours is.
Yeah, I'd go to v18.2 and see if that helps. And then tech support may be willing to help if you're up to date. |
parallel run, partitioner executable |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 22:33 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 14:43 |
