Inflation parameters
Old   February 10, 2003, 10:49
Default Inflation parameters
Adrian Mawdsley
I have set an inflation boundary for my geometry, but when I set the inflation parameters and try to write the definition file I get this error message :-
Volume mesh warning: The surface mesh overlaps itself
Does anybody have any ideas?
Thanks
Adrian
Old   February 11, 2003, 04:46
Default Re: Inflation parameters
Bart Prast
Probably a bad IGES file (if you use one) or a too coarse grid, I would say.
Old   February 11, 2003, 08:13
Bob
It could be that your inflation causes the msh to over lap. eg say we have a 1m^2 duct with an inflation layer of 0.3m on all the walls of the duct, and a global edge length of 0.6m. You may get a problem, as the mesher needs to fit at least one cell between inflation layers. Does your model work without inflation ? Have a look at where the model fails, and look at the geometry in the area. Would the mesh be constricted by the geometry ? bob
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 03:22
units of geometrical parameters lost SoobY ANSYS Meshing & Geometry 2 January 10, 2011 03:58
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
Inflation Parameters Suggestions Scott CFX 1 August 20, 2008 21:12
Inflation Gab CFX 6 August 24, 2005 22:45
