Lagrangian bubble column
Old   November 24, 2017, 11:13
Smile Lagrangian bubble column
wafaa hana
wafaa is on a distinguished road
Hello!
Im trying to do a particle user fortran routine to calculate the added mass coefficient and to do so , I need to find the distance between the particles and the acceleration of each particle.
If you guys can help me with this, it would be much appreciated !
Thank you
wafaa is offline   Reply With Quote
Old   November 25, 2017, 05:36
Is this a eularian or lagrangian particle tracking model?
The distance would be calculated the same regardless of the model - you can work back from the volume fraction and particle size how many particles per unit volume and therefore their average distance apart. Important note - in lagrangian particle tracking models the tracked particles are representative of a population of particles. In other words, there are more particles than is modelled in the particle tracks.
Acceleration is a bit more tricky. I guess if this is lagrangian you can double differentiate the particle position to get the acceleration. I would need to do some thinking to determine this for Eularian models.
Old   November 25, 2017, 09:37
wafaa hana
It's for a lagrangian model
Old   November 26, 2017, 17:36
OK, thanks. Do my suggestions help?
Old   November 29, 2017, 13:06
wafaa hana
The thing is , my professor asked me to isolate 3 air bubbles (in air bubble column) and use the equations to calculate the added mass force that require the distance between the bubble 1 and 2 , the bubble 1 and 3 and also the acceleration of each of those bubbles. I'm not familiar with fortran user routine. If you guide me, that would be appreciated.
Old   November 29, 2017, 16:48
The CFX documentation has several examples of user fortran. There are more on the ANSYS Customer website.
lagrangian, particle, routine, user fortran
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 06:01
Problem: bubble column with twoPhaseEulerFoam hester OpenFOAM Running, Solving & CFD 6 January 22, 2016 12:25
2D bubble rising through a column of water vof64 Fluent Multiphase 0 August 19, 2014 23:42
bubble column ken FLUENT 1 June 30, 2013 01:18
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
