December 14, 2017, 19:45 |
Uniform pressure over the domain
Prashanth Renato
hi guys . i am getting a uniform pressure all over the domain . its full of red .. i cannot able to see where the pressure is lower and higher over and below the drone please help me in this
i am using cfx .. boundary conditions are ... air at 25 deg c , no heat transfer, inlet velocity is 10ms rpm is 3790, sst turbulence model . i even increased the domain size which is 10D full drone size model is 3 meter diameter why its full of negative pressure ? in the contour |
rhoSimpleFoam error | johny0688 | OpenFOAM Pre-Processing | 4 | June 1, 2021 12:23 |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
T Junction Stability | ignacio | OpenFOAM Running, Solving & CFD | 5 | May 2, 2013 10:44 |
singularity? | mihaipruna | OpenFOAM Running, Solving & CFD | 5 | April 24, 2012 17:18 |
