Problem on boundary conditions
Old   June 19, 2003, 03:28
Default Problem on boundary conditions
Miko
Hi all! I have trouble when I define inlet/outlet. I'm confused by how to set pressure. If I want to set the static pressure of Point A (inlet) 50 Pa greater than that of Point B (outlet) and the initial velocity of inlet is zero, how can I put it into practise? Is it right that I specify Mass and Momentum of inlet as Static Pressure with 50 Pa and outlet 0 Pa?
Best regards!
Miko
Old   June 20, 2003, 01:11
Default Re: Problem on boundary conditions
Neale
While this physically makes sense it does not constrain momentum and you may have a lot of difficulty getting a solution as a result. i.e. any momentum flow will give you the solution you want.
I suggest that you run total pressure inlet and mass flow outlet or static pressure outlet until you get the inlet velocity you want.
Neale
Old   June 20, 2003, 08:22
Miko
Hi Neale!
Thank you for your guideline! But I still have problem to understand what you have said.
1. Why does my setting make sense but be unable to get a satisfied solution? Since I have a little idea on CFX modeling, I hope you can give me some explanation in point.
2. According to your suggest, what's the specfic value I should specify, such as total pressure inlet, mass flow outlet or static pressure outlet?
Thank you for your time!
Miko
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
CG, BICGSTAB(2) : problem with matrix operation and boundary conditions moomba Main CFD Forum 2 February 17, 2010 03:37
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 06:25
Problem with Boundary conditions Mahiboobswamulu Main CFD Forum 10 August 26, 2003 13:24
boundary conditions problem reinaldo kuhn Phoenics 1 March 27, 2003 11:46
