updating the mesh of a definition/result file
Old   June 25, 2003, 05:34
Default updating the mesh of a definition/result file
Bony Quach
I'm sorry to bother you again, but I'm really stuck...
Is it possible to update a def/res file with a new mesh, same topologically as the original (same number of nodes &elements), without having to redefine the regions and boundary conditions and everything??? Moreover is there a command in batch mode for doing this? in cfx5?
Is it possible to obtain the original def file from a res file??
thanks
Old   June 25, 2003, 10:55
Default Re: updating the mesh of a definition/result file
cfd guy
1) Create a session file in the new CFX-Pre (or BUILD if you're using 5.5.1) and then play it with your new mesh. You'll get the same CCL file, regions, etc...
2) You can use cfx5cmds to read the CCL: cfx5cmds -read -def example.def -text example.def.ccl
or
Read the res file into CFX-Pre and tell it to write a new def file. Note that you'll lose the solution variables and your problem will be started from the scratch.
Good luck, cfd guy
Old   June 25, 2003, 16:25
Bony Quach
thanks, but I was just hoping there was a way to do it without having to use the gui... to use it in an automatic way with a routine and the command line.
PS : thanks for the Interpolation def res message response!!
Old   June 26, 2003, 04:17
cfd guy
And there is... cfx5pre -batch run.cse
where run.cse is your session file. But to get this session file is strongly advisable that you use GUI when creating it.
Good luck, cfd guy
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
