compressible two phase flow in CFX4.4
Old   July 1, 2003, 23:32
Default compressible two phase flow in CFX4.4
youngan
following is error message and my command file.
CFX-4 | Solver | forrtl: error (73): floating divide by zero CFX-4 | Solver | Image PC Routine Line Source CFX-4 | Solver | psolvempiNT.exe 004BED98 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0044CC18 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0041DEE6 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 004186AC Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0040B73B Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0040541C Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | runsolve4: Job completed CFX-4 | Solver | Output file : /tmp/m07.fo CFX-4 | Solver | CFX-4 | Solver | Finished.
>>CFX4
:>OPTIONS
TURBULENT FLOW
TWO DIMENSIONS
HEAT TRANSFER
COMPRESSIBLE FLOW
LAMINAR FLOW
TRANSIENT FLOW
NUMBER OF PHASES 2
:>MODEL TOPOLOGY
:>CREATE BLOCK
BLOCK NAME 'BLOCK-NUMBER-1'
BLOCK DIMENSIONS 40 20
:>CREATE PATCH
PATCH NAME 'INLET'
PATCH TYPE 'INLET'
PATCH LOCATION 29 31 20 20 1 1
HIGH J
:>CREATE PATCH
PATCH NAME 'PRESS'
PATCH TYPE 'PRESSURE BOUNDARY'
PATCH LOCATION 9 11 1 1 1 1
LOW J
:>MODEL DATA
:>TITLE
PROBLEM TITLE 'test'
:>AMBIENT VARIABLES
TEMPERATURE 2.9100E+02
:>PHYSICAL PROPERTIES
>>COMPRESSIBILITY PARAMETERS
PHASE NAME 'PHASE2'
INCOMPRESSIBLE
PHASE NAME 'PHASE1'
WEAKLY COMPRESSIBLE
UNIVERSAL GAS CONSTANT 8.3140E+03
FLUID MOLECULAR WEIGHT 2.8950E+01
REFERENCE PRESSURE 1.0130E+05
>>FLUID PARAMETERS
PHASE NAME 'PHASE2'
VISCOSITY 1.0000E-05
DENSITY 38.0
>>STANDARD FLUID
PHASE NAME 'PHASE1'
FLUID 'AIR'
STANDARD FLUID REFERENCE TEMPERATURE 2.9100E+02
>>HEAT TRANSFER PARAMETERS
PHASE NAME 'PHASE2'
THERMAL CONDUCTIVITY 2.3400E-04
FLUID SPECIFIC HEAT 1* 0.000000E+00
ENTHALPY REFERENCE TEMPERATURE 2.8800E+02
>>MULTIPHASE PARAMETERS
>>PHASE DESCRIPTION
PHASE NAME 'PHASE1'
GAS
CONTINUOUS
MINIMUM VOLUME FRACTION 1.0000E-05
MODIFY EMPTY CELL VELOCITY 0.0000E+00
>>PHASE DESCRIPTION
PHASE NAME 'PHASE2'
SOLID
DISPERSE
MEAN DIAMETER 1.0000E-03
SOLID PRESSURE
RESTITUTION COEFFICIENT 6.0000E-01
COMPACTION VOLUME FRACTION 6.4000E-01
>>MULTIPHASE MODELS
>>MOMENTUM
INTER PHASE TRANSFER
SINCE
>>INTER PHASE TRANSFER MODELS
>>MOMENTUM
FIRST PHASE NAME 'PHASE1'
SECOND PHASE NAME 'PHASE2'
>>PARTICLE DRAG MODEL
FLOW REGIME 'ERGUN'
>>TRANSIENT PARAMETERS
>>FIXED TIME STEPPING
TIME STEPS 100* 1.000000E-03
INITIAL TIME 0.0000E+00
:>SOLVER DATA
:>PROGRAM CONTROL
MAXIMUM NUMBER OF ITERATIONS 10
MASS SOURCE TOLERANCE 1.0000E-06
:>CREATE GRID
:>SIMPLE GRID
DX 40* 3.000000E-03
DY 20* 3.000000E-03
DZ 3.000000E-03
X START 0.0000E+00
Y START 0.0000E+00
Z START 0.0000E+00
:>MODEL BOUNDARY CONDITIONS
:>INLET BOUNDARIES
PHASE NAME 'PHASE1'
PATCH NAME 'INLET'
NORMAL VELOCITY 3.0000E+00
VOLUME FRACTION 9.0000E-01
TEMPERATURE 2.9300E+02
:>INLET BOUNDARIES
PHASE NAME 'PHASE2'
PATCH NAME 'INLET'
NORMAL VELOCITY 2.0000E+00
VOLUME FRACTION 1.0000E-01
:>PRESSURE BOUNDARIES
PHASE NAME 'PHASE2'
PATCH NAME 'PRESS'
PRESSURE 0.0000E+00
VOLUME FRACTION 0.0000E+00
PHASE NAME 'PHASE1'
PATCH NAME 'PRESS'
PRESSURE 0.0000E+00
VOLUME FRACTION 1.0000E+00
:>STOP
compressible flow maria teresa FLUENT 1 September 7, 2007 16:58
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 04:22
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
