Script to Read and Export all the data in all the trn files |
April 4, 2020, 11:18 |
Dinusha
Rep Power: 6 |
How can I read all the variables and data in *.trn files (transient simulation) and export to csv/excel file using a script? In addition, I also replicate the mathematical I use for one trn file to all the other trn files using a script (or using a macro) Thanks |
April 4, 2020, 12:18 |
M
Rep Power: 12 |
You can create a state or session file in cfd post. To get the correct syntax, record a session where you manually export some values to csv. This will show you the commands you need. Then, I would recommend going to python or whatever language and write a script that recreates the former code but for all the transient files you want. Once you got that, just play the session in post.
April 5, 2020, 11:44 |
Dinusha
Rep Power: 6 |
Thanks a lot, I will try this
April 6, 2020, 05:56 |
Dinusha
Rep Power: 6 |
Any idea to make that applicable to different projects other than the one we create/run the session? (like if I want to use the same export script to export the trn files of different file)
Thanks |
April 6, 2020, 06:06 |
Rep Power: 143 |
Do it using CFX stand-alone (ie not inside workbench). In fact just about all serious users of CFX do it stand alone as CFX runs quicker and with more control that way - your question is one example of why.
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer | wildfire230 | OpenFOAM Installation | 20 | May 6, 2020 07:30 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
read data files and export to avs file | Santhosh | FLUENT | 0 | June 15, 2006 06:46 |
[making animations] fclose fails to close files? | Mika | FLUENT | 0 | March 30, 2001 08:19 |
