January 22, 2018, 07:23 |
Particle tracking, losses
Christian Buchgeher
Rep Power: 8 |
Hey,
Can cfx tell me how many particles make it past a certain point, or just a percentage of them make it? I have a flow through a tube which is connected to cylinders, with holes? I wanna know how many particles get stuck in the cylinders. Thanks |
January 23, 2018, 08:04 |
Gert-Jan
Rep Power: 27 |
What you can do is create a subdomain inside the cilinder. In CFX-Pre you can set the subdomain to absorb all particles when the flow into this subdomain.
Żou can only define subdomains on separate named 3D Volumes. So if you haven't defined a volume inside your cilinder yet, you need to create these first in your geometry and remesh your domain. Take in mind that when the particles are absorbed, they leave the simulation. So, this approach assumes that their effect on the flow inside the cilinder is neglected. Also, they cannot re-entrain into the tube.... |
January 25, 2018, 07:07 |
Christian Buchgeher
Rep Power: 8 |
thanks
However when i switch the 3d volumes to a new body part in icem, i can only choose the whole volume as a subdomain. Do you have any input on that? |
January 26, 2018, 05:03 |
Gert-Jan
Rep Power: 27 |
Subdomains need to be defined in Pre, not in ICEM.......
Let's presume you create the mesh in ICEM. You already have a body point in the volume outside your cilinders. Then: - Create additional body points in each cilinder. - Create internal faces inside your cilinder to make sure that the additional body points are inside a closed volume (These internal faces separates the body point outside the cilinder from the body points inside the cilinder). - go to Mesh>Part Mesh setup. There set the faces as "internal wall". Do NOT put inflation on them. - After mesh generation, import it in Pre. - Use all volumes in your Default Domain (or whatever you named it). - Then create subdomains for each separate cilinder volume and set your absorption diameter. If you set it to 1e-20, all particles will be absorbed. Cheers, Gert-Jan |
January 26, 2018, 05:39 |
Gert-Jan
Rep Power: 27 |
Probably you do not have to set them as "Internal wall". The mesher will detect it automatically as interfaces. Important in the part mesh setup is that you exclude these interfaces from inflation (i.e. prisms).
article losses |
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 09:36 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow | DarrenC | CFX | 5 | April 7, 2016 14:50 |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 18:00 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
