How to create vorticity expression for interrupt control? |
January 27, 2018, 12:31 |
Rep Power: 8 |
Hi, im running a steady state simulation and i need to set up an interrupt control that involves the vorticity value at a certain point.
The thing is that the method/syntaxis i need to use REQUIRES to write the vorticity as an expression, and not just a monitor point. Specifically i need an expression that gets the value of the vorticity at point (x,y,z) = (0,7,2) (it doesnt need to be EXACTLY that point, could also be the average vorticity of an small sphere around that point, for example) I tried putting a named selection of that node in meshing and creating an expresion as vorticity@Node but it didnt recognized the object"node". I tried the same thing using the mesh element of that position instead of the nearest node, but didnt work either. How can this be done? |
January 27, 2018, 17:50 |
Rep Power: 143 |
Can you use the CEL expression probe(variable)@monitor point location? See the CFX reference guide for more details.
January 27, 2018, 21:00 |
Rep Power: 8 |
Thanks, i made it work that way (:
How to create a variable which computes vorticity | cmete | CFX | 7 | October 7, 2017 09:54 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
Help to create a CEL Expression | Juan Maria Campos | CFX | 2 | December 3, 2007 07:52 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
