Multiphase flow modeling
Old   August 5, 2003, 17:14
Default Multiphase flow modeling
Paul
Hi, I am asking a quite general question. I am using CFX4.4 and trying to simulate multiphase (air-water) pipe flow of different flow regimes: bubble flow, churn flow, annular flow, slug flow. My understanding is that CFX4 has two models available: homogenous and two-fluid model. Whatever model I use, I can get good predictions only for cases of bubbly flow with low air void fraction. I have a bad luck for any annular flow even in a straight pipe. I am wondering if there are some tricks for multiphase flow simulations? And also how the multiphase capabilities are promoted in CFX5?For anyone experienced with multiphase flow, your response is appreciated.
Thank you.
Old   August 11, 2003, 05:32
Default Re: Multiphase flow modeling
Aaron Latty
Before you read this, understand that I have only used CFX5 so I don't know what is possible in CFX4:
As a general rule, you are probably better off using the inhomogeneous model if you are concerned with how the bubbles will behave. The homogeneous model assumes that the fluids share a common velocity field. This might be appropriate for some slug flows, but generally, you will get better results with an inhomogeneous model.
Sometimes it is worth adding a third phase or possibly even a fourth phase (of air) to account for the different types of flow. You then have to worry about how these phases interact with each other. For slug flow, for example, you could model water as a continuous fluid, air as a continuous fluid and then create another phase called 'dispersed air' as a dispersed fluid. You can specify the mean diameter of the fluid particle depending on whether you are expecting large or small bubbles.
You can also play around with the free surfance settings. As I understand it, this provides a 'surface sharpening' algorithm that might improve the resolution of the interface between the water and air phases.
Good luck.
Aaron
Old   August 11, 2003, 09:41
Paul
Good point. Thank you, Aaron.
Problems with multiphase modeling magnounibo FLUENT 0 April 30, 2009 03:59
Multiphase flow modeling Paul FLUENT 3 August 16, 2004 14:22
Multiphase flow modeling Paul CFX 0 August 16, 2004 10:07
Multiphase flow with mass transfer? A. Ataki FLUENT 1 November 10, 2003 04:46
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
