[Sponsors] | |||||
#21 |
Rep Power: 11 ![]() |
yes i meant to say that. But where is the 'trap, escaping, reflecting' boundary condition set. Is there any tutorial you can recommend? Thank you . My English is a little bad.
#22 |
Rep Power: 146 ![]() ![]() ![]() ![]() |
On wall boundary conditions you can set what particles do. By default the coefficient of resititution is zero so particles stop at walls, but you can give it a coefficient of restitution if you want particles to bounce. But it sounds like the default condition will act as the "trap" you describe.
#23 |
Thank you very much ghorrocks. I will set the parallel and vertical coefficients to zero to trap when the particles enter a dustbin wall boundary. I adjust the parallel and vertical coefficient to 1 on the cyclone side wall and the vortex finder wall. Did I understand you correctly? Would you please confirm?
How can I learn the number of pieces falling into an escape and a trap? Please help me. |
#24 |
Gert-Jan
Rep Power: 29 ![]() |
If you set them equal to 1, then the particles will bounce from the walls until they find an outlet. Probably, most won't find an outlet and will rotate until they hit the limit in distance, time or integration limit, depending on what you set. So separation efficiency of the cyclone will be low.
If you set them equal to 0, the particles will esacpe from the simulation immediately if they hit a wall. So you will have a very high cyclone efficiency. The reality will be somewhere in between. The values depend on material, shape, humidity, particle size (distribution), etc. You can only find the correct settings if you can compare if with experiments. I told you, that CFD on a cyclone can be a real pain in the "...". Good luck, Gert-Jan |
#25 |
Mr. Gert-Jan and Mr. Glenn Horrocks, I would like to thank you for sharing your valuable information. thanks to you guys we learn something. I'll find the right settings by comparing it with the books. Thank you again .
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 15:04 |
| cyclone analysis error | arjun3020 | FLUENT | 4 | May 15, 2014 02:05 |
| Convergence of Cyclone Analysis | arjun3020 | FLUENT | 5 | April 25, 2012 02:50 |
| Cyclone analysis | subramaniam.CR | CFX | 1 | March 5, 2005 11:22 |
| Modelling Industrial cyclone behaviour | Günther Hasse | Main CFD Forum | 3 | October 12, 1999 20:34 |
