Supersonic flow
Old   February 11, 2018, 05:13
Exclamation Supersonic flow
bhargav
bhargavkalathiya is on a distinguished road
I am doing CFD of turbomachine operating in supersonic flow in absolute frame. I am using CFx 17.1
Solver : k-w
I have set reference pressure as 0 Bar
Specified inlet conditions
total temperature in stationary frame: 300 K
total Pressure in stationary frame : 101325 pa
And inlet velocity : 500m/s
Outlet : I left it as supersonic (Is it good approach?)
My fluid domain is small so I kept outlet as supersonic. Length of inlet and outlet domain is approx 320 mm.
But I can see that velocity in result file is unbelievable and at inlet is of order of 3000 m/s !!!
I have uploaded velocity contours, mach number contours, monitor of velocity during run at inlet (this velocity is area average over inlet) and residuals.
Please....Can somebody help me What I am doing wrong here?
Thank you so much.
bhargavkalathiya is offline   Reply With Quote
Old   February 11, 2018, 18:30
Gert-Jan
Gert-Jan will become famous soon enough
Step 1: Using Bernouilli-equation, calculate the static pressure on the inlet based on the conditions you provided. Then you'll see what is going wrong.
Step 2: Change it into something realistic.
Gert-Jan is offline   Reply With Quote
Species Transport Convergence trouble in Supersonic Flow BrianF16 FLUENT 0 February 28, 2017 12:18
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 15:13
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech enriccasas FLUENT 1 August 21, 2013 06:43
Producing a supersonic flow in a constant diameter cylinder clgs.1903 FLUENT 12 May 24, 2012 13:41
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
