roughness of thin surface
Old   October 27, 2003, 22:12
Default roughness of thin surface
colins
hi,friends I need to difine different roughness on the twos of thin surface,who knows how to? I have referred to this topic, http://www.cfd-online.com/Forum/cfx_....cgi?read=4397 but I can not distinguish the two surfaces,e.g. which one is the inside one or which one is the upper,anyone could help me? thanks.
Old   October 28, 2003, 12:41
Default Re: roughness of thin surface
Robin
Hi Colins,
To find the direction, define an outlet boundary condition to the surface. The arrows will be on the side which is touching the fluid. You can then switch it back to a wall and apply the appropriate B.C.
-Robin
Old   October 28, 2003, 22:03
colins
To robin, I have tried following what you suggested,but I cannot apply a inlet/outlet boundary on a subdomain surface,the error reported was "The surface list 'Solid 4.4' contains the following error(s). Solid 4.4 is not an exterior face of a domain." Btw,I am using CFX5.5 -colins
Old   October 29, 2003, 03:05
njzeo
first,you can creat a subdomain which include the thinsurface you will defined,then in the condition boundary,you'd creat the thinsurface,and you may define different roughness on the two side of the thinsurface.may you succeed1
Old   October 29, 2003, 12:06
Robin
Upgrade to 5.6.
-Robin
Old   October 30, 2003, 00:13
colins
To Robin, thank you.I have done it. -colins
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Surface roughness alefem FLOW-3D 6 June 3, 2010 12:49
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
