November 5, 2003, 22:22 |
How import the mesh generated in fluent5.4
Now I have a model and mesh generated in fluent5.48,and I want import it into cfx5.6,how can I make it? Ask all you guys for appreciating help!
Thanks 1 |
November 6, 2003, 17:51 |
Re: How import the mesh generated in fluent5.4
If you have knowledge/documentation of the Fluient grid format then you could write your own grid importer using the cfx user defined grid import library?
Neale |
November 7, 2003, 20:05 |
Thanks!
It is a great pity that I havenot such knowledge of the Fluient grid format!Do you have such expierence which you are willing to share with our guys? |
November 10, 2003, 18:17 |
I don't know what the Fluent format is. Perhaps you could ask your Fluent service rep? I was given the impression one time that the Fluent documentation describes the format.
Neale |
November 6, 2003, 23:18 |
Have you considered ICEM CFD? ICEM can read a Fluent mesh, just not sure abouth the version.
cheers, Derrek |
November 7, 2003, 20:03 |
Great thanks at first!
You mean I can read the mesh by use of ICEM-CFD,and then export to the proper format which cfx-5.6 can use? |
November 10, 2003, 23:38 |
yes, that is right!
November 13, 2003, 03:35 |
Thanks a lot! I will try now!
November 13, 2003, 19:54 |
Try using a patran neutral file export from Fluent (.neu), and then import it into CFX-Pre. That has worked for me.
November 18, 2003, 09:17 |
Yes,it really worked.Thank you very much!
I have successly made it! |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
CFX mesh import from ICEM (Windows) | Andrew | CFX | 7 | July 6, 2006 11:39 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
