.trk file variables in particle tracking
Old   September 17, 2010, 10:55
Default .trk file variables in particle tracking
cfdatrmit is on a distinguished road
Hi all,
I've been looking in the manuals for information on the particle tracking file. Does anyone know what the variables that CFX outputs into its .trk file from particle tracking. I tracked one particle stream and opened the .trk file in notepad which gives this:
105
1 -2.000000 4.520412 4.128771 0.0000000E+00
0.0000000E+00 4.9999999E-06 7662425. 1.000000 0.0000000E+00
0.0000000E+00 6.5253494E-14
1 -1.900000 4.520165 4.128793 0.1539223
0.1000004 4.9999999E-06 7662425. 0.6268228 -2.4222441E-03
2.1734087E-04 6.5253494E-14
1 -1.538350 4.518776 4.128928 0.7284727
0.4616528 4.9999999E-06 7662425. 0.6330290 -2.2362103E-03
2.4497270E-04 6.5253494E-14
1 -1.301596 4.517958 4.129019 1.101518
0.6984086 4.9999999E-06 7662425. 0.6369488 -2.1575745E-03
2.4162982E-04 6.5253494E-14
1 -1.180058 4.517548 4.129065 1.292174
0.8199469 4.9999999E-06 7662425. 0.6389125 -2.1305513E-03
2.3861929E-04 6.5253494E-14
1 -0.8277293 4.516370 4.129196 1.842072
1.172278 4.9999999E-06 7662425. 0.6431691 -2.1652121E-03
2.3706595E-04 6.5253494E-14
.... and so on...
Also is there a way to extract certain particle variables out and output them into a file itself?
Thanks!
cfdatrmit is offline   Reply With Quote
Old   February 16, 2012, 02:35
AKS
cfd_begin is on a distinguished road
Hii,
I am facing the same problem. Have you solved it. plz let me know....
cfd_begin is offline   Reply With Quote
Old   April 1, 2018, 02:50
Suman Sapkota
Suman Sapkota is on a distinguished road
I am conducting a steady state analysis of pump and I am looking to track the particles (more or less same example as butterfly valve with erosion tutorial). The problem is I am only generating blank particle file. The .trk files are simply empty. Also, the .trk file is only created for 1 particle with pT1.trk file. How do I keep track of all the 20 particles? Do anyone has a way around it? or, helpful links?
While I am at it, would it be possible to generate impact velocity data of those particles from CFX?
Suman Sapkota is offline   Reply With Quote
lagrangian, particle position
tecio compilation errors in latest 1.6.x rsamuel OpenFOAM Bugs 2 June 25, 2021 08:10
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
