Optical Thickness
Old   November 24, 2003, 09:34
Default Optical Thickness
Jonathan
Hello CFX-Users,
I am setting up a model where I want to consider radiative heat transfer and CO2 and H2O vapour are definitely present.
I understand from the manuals that knowing the optical thickness is important in selecting the most appropriate Radiation model.
Does anyone know how to calculate the optical thickness?
Thank you, Jonathan
Old   December 22, 2003, 13:25
Default Re: Optical Thickness
Jonathan
Using Beer's Law and curves from Hottel and Sarofim will do the trick for H2O and CO2. Siegel and Howell's text is very helpful - Thermal Radiation Heat Transfer.
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 03:22
Momentum and displacement thickness: du/dy calculation Josh CFX 13 October 27, 2013 14:38
Calculating displacement and momentum thickness from Fluent VSAndroid Main CFD Forum 0 April 14, 2011 13:45
optical thickness ehrenwirth CFX 5 June 26, 2009 11:36
Max Optical thickness for Discrete Ordinate Modell Thomas FLUENT 0 April 13, 2005 07:13
