Can't get the right shock wave in a supersonic flow |
April 9, 2018, 19:17 |
Alex
Rep Power: 8 |
Mode: Trancient
Domain setup: Air ideal gas, Total energy, Laminar, Reference pressure = 1 atm. Inlet: supersonic, velocity = 450m/s, relative pressure = 0pa, temperature = 300K. Outlet: supersonic. Initial conditions in domain: velocity = 450m/s, temperature = 300K. Achieved convergence: less than 1e-04. Hello. I'm trying to get a conical shock wave shape around the central spike (as it happens in the ramget engine), like this: But I get a straight front, which spreads farther and farther from the central spike. Opposite the supersonic flow. This looks strange and improbably. So, what I'm doing wrong with the setup? |
April 10, 2018, 02:45 |
M
Rep Power: 12 |
Try to understand what you are looking at. What does the Mach distribution near the wall tell you? What happens to flow within a nozzle?
April 10, 2018, 04:25 |
Gert-Jan
Rep Power: 27 |
@ Alex
- why oh why do you try to run the most difficult case from scratch? That is asking for problems. - why not try simple and increase complexity with every restart: 1) steady state; inlet vel = 10 m/s 2) steady state; inlet vel =100 m/s 3) steady state; inlet vel =300 m/s 4) steady state; inlet vel =450 m/s 5) transient; inlet vel =450 m/s Don't try to hit the roof in one go, and expect CFX so solve all your problems in one step. It is not a panacea. That's a silly approach. Last edited by Gert-Jan; April 10, 2018 at 07:34. |
April 10, 2018, 04:50 |
urosgrivc
Rep Power: 11 |
first problem -> temperature = 300K, what fixed like isothermal? total energy ideal gas might be considered
Are those walls near the body and is the cone in the tube? or are you are simulating a cone in free flow what about axisimetry also do you have a 2d flat or axisimetric |
April 10, 2018, 12:18 |
#5 | ||||
Alex
Rep Power: 8 |
Yes, this is the cone in the tube. Quote:
April 11, 2018, 02:59 |
Gert-Jan
Rep Power: 27 |
What you see in your figure is how CFX tries to recover from an initial guess of 450 m/s everywhere. As a result the flow is chocked between your obstacle and the wall. Therefore no more gas can get through which leads to corrections in the flow upstream. The velocity will decrease and it is likely that your inlet is blocked for 100%.
So your figures show how CFD tries to recover from a completely unrealistic initial condition with 450 m/s everywhere. You won't get very far with that as a start. Therefore you need to start slowly and ramp it up with increasing velocity. You mentioned that you could not get it to supersonic flow using this approach. You have to try harder. If this is not going to work, then the approach shown above won't work as well. |
shockwave, supersonic |
Supersonic flow over an airfoil. FLUENT Lift don't match up with Shock Expansion Tech | enriccasas | FLUENT | 1 | August 21, 2013 06:43 |
Producing a supersonic flow in a constant diameter cylinder | clgs.1903 | FLUENT | 12 | May 24, 2012 13:41 |
Scaling up a wave energy converter - free surface flow | mark_l | CFX | 3 | February 17, 2010 16:57 |
Question about the shock wave | nucharin | CFX | 2 | January 27, 2005 04:44 |
Nozzle Flow with shock | jim clancy | FLUENT | 1 | December 18, 2001 04:19 |
