May 3, 2018, 08:46 |
Inserting a momentumsource in CFX 18.0
Maria Carvalho
I am quite new to this community and to CFD; this is may first question. I searched for an specif answer to may question, but could't find any. Here it is: I need to insert a momentum source in the 18.0 version of Ansys. I want to make my simulation as simple as possible and therefore I want to simulate a fan with a point source, as I already simulate a gas leak using a continuity source. The problem is I cannot find this option in CFX Pre. All I get besides continuity is total energy, kinetic energy and turbulence eddy dissipation. Thanks for any help. |
May 3, 2018, 16:48 |
Gert-Jan
Rep Power: 27 |
When I open Pre, I see an icon in the ribbon, that allows me to specify a Source Point. Left to it there is an icon where you can insert a Subdomain, which can be used to define a volume source.
Isn't that enough? I would think it gives enough possibilities to fullfill your needs, not? |
May 3, 2018, 16:56 |
Rep Power: 32 |
unfortunately, momentum sources are not available for source points.
You may have to isolate the specific element in the mesh (outside CFX-Pre), and then you can select that element as a subdomain. I do not see an alternative way at the moment. Is the fan that small ? |
May 3, 2018, 17:04 |
Gert-Jan
Rep Power: 27 |
Yes Opaque is right. You should create a small volume as Subdomain. That will provide a momentum source.
ansys 18.0, cfx, fan as momentum source, momentum sources |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
Different flow pattern between OpenFOAM and CFX | AirS | OpenFOAM | 0 | January 12, 2010 07:08 |
CFX Post - Inserting additional geometry | Andrew | CFX | 2 | April 18, 2007 08:27 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
