May 20, 2018, 17:06 |
Values of an "user point"
Marcello Asciolla
Rep Power: 8 |
I did a simulation from Workbench and in CFX Pre I defined as an "user point" the value of mass flow at a section.
This is an example of a simulation, but where are stored these results in the files? Time.JPG |
May 20, 2018, 19:22 |
Rep Power: 143 |
The format of the res file is propriety so you are not going to find the details of where it is stored.
I suspect you are actually asking how can I get the raw data from the plot - In solver manager right click on the chart and select "Export Plot Variables". Alternately you can use the command line cfx5mondata to extract it.
May 22, 2018, 02:43 |
M
Rep Power: 12 |
FYI: the mass flows at the boundaries are also predefined monitors, check Plot Lines -> Flow -> <choose boundary> -> P-Mass Boundary Flow on <boundary>
user point |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 03:59 |
Setting patch field values equal to internal field values | leroyv | OpenFOAM Programming & Development | 1 | October 21, 2014 15:49 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
