Particle simulation in CFX 5.6
Old   March 16, 2004, 08:07
Default Particle simulation in CFX 5.6
Jens
Hi
I have a problem with the particle simulation in CFX 5.6. I inject particle in 5 different mass range into a pipe system.
But after 1/4 of the pipe lenght the particle track stops.
Why is this happing ?
Any hints.
Regards
Jens
Old   March 18, 2004, 06:57
Default Re: Particle simulation in CFX 5.6
Bob
Jens, could be the simultion time of the particls has run out ? There is a time limit in the setup and if the particls are still in the domain when this time limit runs out then they just stop. Check through the GUI's and on particle setup and you will find this, just make it larger and it should solve your problem Bob
CFX steady simulation gharek CFX 1 April 7, 2010 18:41
cfx particle convergence problem bharath CFX 0 November 11, 2009 08:34
CFX particle tracking Mehmet SORGUN CFX 0 February 4, 2009 13:24
CFX diffuser simulation Ianto CFX 8 November 20, 2008 02:45
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
