March 3, 2010, 11:32 |
Post-Processing with Symmetry
Rep Power: 17 |
How do you plot results for the full domain if symmetry was utilized in the analysis? Thanks so much for any information!
March 3, 2010, 18:02 |
Rep Power: 143 |
Use a transformation to get it to mirror at the symmetry plane. Some of the CFX tutorials do this, have a look there.
June 21, 2010, 10:40 |
Rep Power: 17 |
For those who are interested, I found a tutorial on ANSYS' site showing the steps using the Reflect/Mirror tool. With CFD-Post loaded, click File > Load State and select the .cst file. Right click in the graphics menu, and click Reflect/Mirror. Post asks "Which direction do you want the normal in?" Click the axis desired for mirroring the geometry. The .cst file should be located in the file structure dp0\CFX\Post. If the project involves multiple design points or cases, then go to the respective folders for the appropriate design point (dp1, or dp2, etc.) or for the appropriate case (CFX-1 or CFX-2, etc.).
January 13, 2016, 18:38 |
anonymous
Rep Power: 14 |
Hey All
Sorry to bring up an old dead topic. But I created a reflect/mirror using the right click method listed here. Now I cannot seem to figure out how to get rid of it. I try using the same method (right click on wireframe and see option for mirror/reflect) however it only seems to be an option to create it, not remove it onces its already made. Anyone know how to remove a mirror/reflect once already made? |
January 14, 2016, 01:48 |
Rep Power: 143 |
Every object will have a transformation option as part of its settings. You can remove the mirror transforms by removing the transformation option in each object.
January 14, 2016, 12:13 |
#6 | |
anonymous
Rep Power: 14 |
Before reading this while trying to take screen grabs I actually noticed that there is the "default transform" option under the "user locations and plots" heading in the Outline tree. I managed to change that to match another case which removed my mirror. This one had stumped me for a while causing me quite the headache. Note to developers, when you have a right click option to turn something on......keep it there to turn things off as well. It also doesn't help when the solution in the help documents is to push undo twice. |
June 24, 2016, 01:28 |
upender singh
Rep Power: 11 |
Hi, my model is axi-symmetric. What is the procedure to generate the complete geometry for visualization in this case?
June 24, 2016, 10:25 |
Rep Power: 32 |
Double click on the axisymmetric domain, and look at Instancing. You can make as many copies as you need to form the full circle
June 24, 2016, 19:04 |
#9 |
upender singh
Rep Power: 11 |
Hi opaque,
thanks for the reply. I tried increasing the instances beforehand but too many of them overload my computer. I was wondering, if in any way I could increase the angle of the 3D wedge that shows up in the graphic window by default. Update: I have used a axis-symmetry condition in the mesh modeller. I can see that the mesh can be viewed in 3D. In static structural module, using such type of condition reflects in post-processing sessions. Is there a way to do the same for fluent and cfd post sessions? Regards |
January 12, 2017, 10:59 |
#10 | |
Zari Musavi
Rep Power: 12 |
would appreciate if you or other CFDiers could suggest solutions. /Zari |
January 12, 2017, 16:30 |
#11 |
Rep Power: 143 |
This is the CFX forum. Try the fluent forum for Fluent issues. But I presume you are using CFD-Post which is the post processor for Fluent and CFX. You can set this by changing the default transform options. Have a look in the CFD-Post tutorials for examples of how to do this.
January 16, 2017, 05:49 |
#12 |
Bruno
Rep Power: 21 |
When you load a 2D case from Fluent in Post, it is "extended" to 3D: planar 2D gets extruded, axy-symmetric 2D becomes a wedge.
With that in mind, just use the instancing method described above by Opaque. |
May 24, 2018, 13:12 |
#13 |
sandy
Rep Power: 13 |
Hi all,
Is there a way or workaround to export results for a 360 deg model from this symmetry model ? Thanks Sud |
May 24, 2018, 13:48 |
#14 |
Erik
Rep Power: 23 |
For 360 deg, just use an instance transform with a rotation, instead of a reflection.
For example, if you did 1 degree simulation, make 360 copies, and do rotation of 1 deg about your center axis. If you modeled 2 deg, do 180 copies, and rotate 2 deg. |
May 24, 2018, 17:07 |
#15 | |
sandy
Rep Power: 13 |
I wanted to export that 360 deg data into an excel file. Is that possible ? Thanks Sandy |
May 25, 2018, 02:51 |
#16 |
Gert-Jan
Rep Power: 27 |
I suggest to do the rotation in Excel. Should nopt be too difiicult..............
June 16, 2018, 09:30 |
need your hlep
#17 |
leo
Rep Power: 8 |
i do a simulation with fluent 2D axi-symmetric model,i want looking 3D graphics by post processing,how can i do it in CFD-POST???
June 17, 2018, 07:07 |
#18 |
Rep Power: 143 |
Use an Instance Transform (tutorial: https://sharcnet.ca/Software/Ansys/1.../i1313639.html)
June 17, 2018, 08:10 |
#19 |
leo
Rep Power: 8 |
thank u for your reply,i just try it .
i think it is firstly create a reflection plane,then ,create a instance transform,last i can apply the new transform to graphics objects. but the result is bad,it is still a 2d geometry , jsut 2d symmetric geometry,not 3d ,how can i do it? thank u again |
#20 | |
leo
Rep Power: 8 |
i think it is firstly create a reflection plane,then ,create a instance transform,last i can apply the new transform to graphics objects. but the result is bad,it is still a 2d geometry , jsut 2d symmetric geometry,not 3d ,how can i do it? thank u again Quote:
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 12:44 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
Urgent help needed in post!!. processing results.. | Deadly | FLUENT | 0 | August 21, 2002 00:42 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
