External Flow Pressure
Old   May 5, 2004, 13:07
Default External Flow Pressure
Meri
Hello All, I am making a model of external flow over a wing. I am interested as part of my simulation on the pressure on the exterior of the wing. I set the reference pressure at inlet to 1e05 pa. and at the outlet to 0.0 Would this be the correct way to ensure I get correct pressure on the wing ? or am I missing something. I need help here from any one with experience or knowledge. Thanks
Old   May 5, 2004, 18:40
Default Re: External Flow Pressure
Hi Meriba,
Set the reference pressure as the approximate average absolute pressure in the simulation. If pressures do not deviate much from atmospheric then you can you 101.3kPa for the reference pressure.
For aerofoil simulations generally you are trying to find the drag and lift at a given velocity. The best way to set this up is to set the inlet as an inlet with the velocity specified, and the exit as an outlet with zero relative pressure.
Regards, Glenn
Old   May 6, 2004, 10:36
Meri
Glenn, Thanks for the clarifications. Cheers. Meri
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Pressure Differential Flow Meter alfiecat7 Main CFD Forum 0 June 8, 2011 10:55
internal flow and external flow ? Pathway0320 FLUENT 1 November 17, 2006 03:37
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
