CPU:Intel 3.0E or 3.0C
Old   May 23, 2004, 15:40
Default CPU:Intel 3.0E or 3.0C
Andrew
Hi, all
I want to buy a PC with Intel CPU 3.0GHZ for CFX modelling in this month. Initially I choose Intel 3.0E because it has 1M cache. But a friend said 3.0 E has big problem in cooling if I want to run the program for a long time...
If anyone is using Intel CPU 3.0 E, could you please give some suggestions? I am also intertested in the comparison between Intel 3.0 E and 3.0 C for CFX cumputation. I may change to 3.0 C if no great difference between the two versions .
Thanks!
Andrew
Old   May 23, 2004, 18:40
Default Re: CPU:Intel 3.0E or 3.0C
Hi Andrew,
I don't know the difference between the two, except that the larger cache shows some speed increase on the spec website (www.spec.org). I don't know if that maps across to faster CFX runs.
I do know that hyperthreading actually slows CFX runs down. CFX does not support hyperthreading, so if you have a chip with hyperthreading you will run faster if you disable it. (BTW: I understand you can disable it in the bios.)
Regards, Glenn
Old   May 24, 2004, 13:00
Andrew
Hi,Glenn
Thanks for sharing your experience!
Regards!
Andrew
