Turbine analysis of the turbocharger
Old   September 20, 2018, 21:57
Default Turbine analysis of the turbocharger
seunghyeon, yun
YOUNS is on a distinguished road
Hello guys.
I work CFD analysis by turbine and turbine housing of the turbocharger(twin scroll, Inlet scroll of turbine housing is two.).
Final purpose is verify thermal distribution on the Backplate which is backside radial turbine.
Here, I have boundary conditions from engine by Inlet temperature, Inlet mass flow, Outlet pressure and turbine speed.
This is:
Inlet Temperature: 922.6 deg.C
Inlet Mass Flow: 0.27 kg/s
Outlet Pressure: 188.8 kPa
Turbine rotational speed: 160,000 rpm
Here, I set mass flow 0.135 kg/s and 922.6 deg.C each inlet ( 0.135 + 0.135 = 0.27 ), rotation speed: 160,000 rpm.
But, To you guys know, it can't set total pressure at outlet.
So I set 0.27 kg/s mass flow.
But.... I gave the message "Overflow" from CFX solver....
Mach number is expressed very high in solver message...
How to set boundary condition by this condition?
YOUNS is offline   Reply With Quote
Old   September 21, 2018, 06:36
Defining the mass flow in and out is numerically badly posed. It is never going to converge. Read the CFX documentation on choice of boundary conditions and the best practises guide for turbomachinery.
In you case you should probably put a mass flow outlet boundary and a total pressure inlet.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Cfd analysis of 3 blade water turbine basilsunnym FLUENT 2 September 6, 2015 04:10
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
1d analysis and simulation of gas turbine power plant sridhar.d009 FLUENT 0 September 28, 2010 07:46
1D analysis and simulation of gas turbine power plant sridhar.d009 Main CFD Forum 1 September 28, 2010 07:38
Tutorial related to flow analysis of Hydro turbine Sanjay Jain FLUENT 0 April 10, 2008 09:09
