stoke component
Old   May 30, 2004, 11:01
Default stoke component
Sara
Hello everybody,
question:
what is the significance of the stoke component, in flows?
- is this just the synonym for secondary flows like vortices in a dead angle,
or does this terminology refer to viscosity effects on results,
or other?
Thank you
Old   May 30, 2004, 18:28
Default Re: stoke component
Hi Sara,
I don't know what you mean. Stokes flow is very low Reynolds number flow where the flow is laminar, strongly dominated by viscous effects and there are no seperations. Is this what you are referring to?
Regards, Glenn
Old   May 31, 2004, 11:04
Sara
Hello Glenn,
first thanks for the definition. I believe that's the one: appears as if your definition fits the 'dead angle' circulating flow, as with a step changed cross section chanel flow, mentioned previously. Confirmation appreciated.
Best regards, Sara
Old   June 14, 2004, 10:10
sarabolz
I overlooked 'no separation'
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 02:40
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 07:37
Stoke component Sara Main CFD Forum 0 May 28, 2004 06:42
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 12:20
