Reynolds number in Source Term
Old   July 17, 2018, 07:16
Question Reynolds number in Source Term
kastarkas
kastarkas is on a distinguished road
Hello everyone,
I came across a source term for gas transport with diffusion.
The source term consists of "Reynolds number" term. So while creating CEL's, apparently there is velocity in that. (i.e the "velocity" variable from variables list)
and we know CFX doesn't allow for "non scalar variables" (in this case, velocity) in source terms;
Since I had different cross sections in my flow path, I went that way.
So should I compute velocity based on my geometry and flow rate, may be at inlet and then use it ? Is this right, (coz I have diff cross sections) ?
Thanks for any suggestions or inputs in advance..
kastarkas is offline   Reply With Quote
Old   July 17, 2018, 19:59
Opaque will become famous soon enough
As far as I recall, the Reynolds number does not depend on velocity (velocity is a vector), but a characteristic speed (is a scalar)
It is not clear what you meant about source cannot depend on "non-scalar variables". If the source term is for a scalar equation, it cannot be a function of a vector. Perhaps a function of the magnitude of the vector, but not the vector itself.
Opaque is offline   Reply With Quote
Old   July 18, 2018, 01:51
Thumbs up
kastarkas
great. Thank you Opaque; my bad it was; slightly got confused with velocity and speed; magnitude of velocity worked.
Thanks again.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
