June 3, 2004, 04:29 |
Poisson equation Cfx 4.4
I need model the value of a user scalar V in the fluid domain (but indipendent by the fluid).
The associated equation is similar to the heat conducting in solid. D=gradient D.(k*D V)=S How can I solve this equation in Cfx 4.4? Thanks Andrea |
June 3, 2004, 19:49 |
Re: Poisson equation Cfx 4.4
Set up an additional scalar (V) and under the DIFFERENCING SCHEME set NO CONVECTION.
Set values on all walls or leave alone for zero flux. Unfortunately, inlets are a bit trickier as they will still try to convect or diffuse a zero value into the domain. I've solved this before in USRBCS by: * Loop over each cell in the inlet patch * examine the first adjacent cell to the boundary node * set the inlet to that value This, in essence, gives a zero flux condition on the INLET patch. You may have to do this on PRESSURE patches as well if there is inflow. Good luck, Jeff |
August 17, 2004, 05:34 |
I heard it is possible to solve the NO CONVECTION problem for inlets by using BCSEXT subroutine, but I have no idea about this, because it is not included in the document. How does it works?
Thanks |
CFX Additional Variable Transport Equation | Scott Nordsen | CFX | 3 | January 30, 2010 05:36 |
pressure poisson equation on staggerred grid | chandra | Main CFD Forum | 9 | May 5, 2005 06:01 |
Modified Equation for CFX algorithm | Craig Johansen | CFX | 0 | August 27, 2004 23:02 |
Tecplot & CFX 4.4 | S. H. Kim | CFX | 3 | December 20, 2001 06:07 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
