A question about .eps images using CFX5.6 post
Old   June 15, 2004, 07:42
Default A question about .eps images using CFX5.6 post
Forrest
Hi all,
I am trying to generate some colour images using CFX5.6 post and I suppose .eps is a very good format to get images with good qualities. The question is that the post generates the image together with the large background, which makes the file size quite large. When I insert the .eps iamge into other document (e.g. word) I have to scale or/and crop it in order to fit with text. Is there any way to set up the output of the image, say the image size, or the background size? Sometimes I don't need the images showing the axes then I get rid of it, but it seems no way to get rid of the bottom right logo, any idea? Thank you for your help
Regards Forrest
Old   June 16, 2004, 02:23
Default Re: A question about .eps images using CFX5.6 post
Michael Bo
When including pictures into MS Word I use PNG files for an optimum between quality and file size. EPS/PS is a better quality but PNG's are very small in file size. Also PNG's can easily be edited using a standard picture editing program.
Old   June 16, 2004, 04:54
Forrest
Thank you Michael for your advice, yeah, you are right, png files work quite ok for colour image in word. Only bit fuzzy for vectors and mesh. I will use it as an alternative, especially for thesis writing, file size can be a problem.
Regards, Forrest
Old   June 16, 2004, 06:40
Michael Bo
You could increase the pixel size to reduce the fuzzy vectors in a vector plot. Try increasing the size to 1263*1024 pixels (1,3 Mega) or even higher 1579*1280 pixel = 2 Megapixels.
Old   June 17, 2004, 04:52
Forrest
Thank you Michael, Increasing the resolution does help! Cheers, Forrest.
Old   June 17, 2004, 22:39
Jeff
Forrest,
Once you get the png image into Word or Powerpoint, go to picture properties (format image?) and you can crop the edges in to get rid of any axis or logos that you don't want. Of course you can just disable the axis under edit|options, but the logo is hard coded. Just make sure your model image is just inside the rectangle you'll be cropping to.
Jeff
Old   June 18, 2004, 03:24
Forrest
Thank you Jeff, I did use 'crop' a lot in word for these images generated using CFX5.6 post.
All the best, Forrest
CFX 11 Post question DAK565656 CFX 0 October 2, 2008 10:17
how i can post picture here to show my question? prayskyer CFX 2 October 8, 2006 06:47
Post processing question Q Main CFD Forum 4 March 3, 2006 13:53
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 11:59
I post a question and all I get is gibberish Dean Schrage Main CFD Forum 30 September 12, 2001 19:51
