August 1, 2018, 05:41 |
External Gear Pump - CEL expression query
Hello everyone,
Currently, I'm working on the project related to External gear pump in CFX using Immersed Solid Method. Subsequently, I preferred to validate the model of Yoon et al. (2014) [Attachment 1]. Yoon's model has been designed and resolved by CFX. However, during post-processing - I face the difficulty while interpolating my result with Yoon's model[Attachment 1 - Fig. 8]. Attachment 2 will give an overall view. The calculated Angular velocity during simulation [obtained from pre-processing] is multiplied with time and 180/pi to give an angular rotation of GEARS in degree (X –axis in the graph). However, this CEL expression fails to fit my curve result with Yoon's model. Query: In need of appropriate CEL expression to calculate the rotation of GEARS in degrees as prescribed in Yoon's paper on Fig. 8 – in order to replicate the figure for validation. Thank you ^^ p { margin-bottom: 0.1in; line-height: 120%; } |
August 1, 2018, 06:29 |
Rep Power: 143 |
The fact that your results are changing as you change the time step size shows that your time step size is too coarse. You need to refine it until it converges - this is called a sensitivity study. After doing a time step size sensitivity study you should do a sensitivity study on convergence criteria and mesh size as well. This is standard practise for all new simulations.
Does "Euler Angle X" (or Y or Z) work to get your rotation angle?
August 1, 2018, 20:39 |
Rep Power: 11 |
What are you using for Momentum Source Scaling Factor ?
Outlet boundary condition in interFoam | Andrea_85 | OpenFOAM Running, Solving & CFD | 51 | July 20, 2017 13:31 |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
External Gear Pump | interawe | ANSYS Meshing & Geometry | 0 | April 14, 2009 17:55 |
Size of Inlet and Outlet for an External Gear Pump | interawe | FLUENT | 0 | April 14, 2009 17:46 |
3D External Gear Pump | Mustafa Ayad | FLUENT | 1 | January 26, 2009 09:55 |
