October 8, 2018, 07:41 |
CFX heat transfer not working
Israel
Rep Power: 7 |
Many Thanks |
October 8, 2018, 07:55 |
urosgrivc
Rep Power: 11 |
Did you make all the needed interfaces and turned on heat transfer in the second tab in the interface settings?
You need to specify fluid-solid connections otherwise these are not connected ... (..later in time) Ok I see you have made connections Outlet could be just pressure opening And I am not sure jet why there is no trn.files created .. (..later in time) Ok it is working now I have decreased the mesh size from 4mm to 2mm as it was really coarse It would be good to add some inflation layers on the fluid walls I have merged both bodies into one part to obtain a conformal mesh at the interface Changed the outlet to opening Initialize the velocity of water to 50mm/s in the correct direction I have set solid timescale factor to 100 Last edited by urosgrivc; October 8, 2018 at 08:59. |
October 10, 2018, 09:37 |
Initial temperature of the copper pipe
Israel
Rep Power: 7 |
I made the changes that you suggested
and it seem that the initial condition of the pipe isn't set, i.e the pipe start at final temperature of the water 20 C, and not in it initial temperature 90 C |
October 10, 2018, 18:25 |
Rep Power: 143 |
Setting initial conditions is very basic stuff. Have a look at the CFX tutorials for how to set up initial conditions.
cfx, heat tranfer, tube |
How does CFX treat an opening when heat transfer is modelled? | JuPa | CFX | 2 | September 9, 2014 05:34 |
CFX conjugate heat transfer problems | dingsheng1206 | CFX | 7 | February 13, 2014 13:29 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
CFX wall heat transfer coefficient | mactech001 | CFX | 1 | January 5, 2010 21:33 |
