Could someone tell me wether CFX5 can simulate axial compressor with Mixing-Plane-Method? With which turbulence model?
Thanks |
Hi Wang,
The Stage (mixing-plane) interface model will do what you are requesting. It is fully conservative and compatible with all turbulence models, including Laminar, Zero Equation, k epsilon, RNG k epsilon, k omega, SST, DES SST, Reynolds Stress, SSG Reynolds Stress, QI Reynolds Stress, BSL Reynolds Stress, and more... Regards, Robin |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Is Particle Finite Element Method applied in CFX? | WenZyn Lim | CFX | 0 | April 6, 2011 11:47 |
Meshing a Mixing Plane in ICEM | Will Anderson | ANSYS Meshing & Geometry | 2 | November 9, 2010 09:16 |
MFR and mixing plane boundary . | Mica | FLUENT | 0 | January 26, 2007 09:39 |
difference in MRF and Mixing plane | sam | FLUENT | 0 | November 18, 2006 11:34 |
