What initiated combustion?
Old   October 5, 2004, 17:32
Default What initiated combustion?
Tony
Hi, All,
I followed the cancombustor tutorial. I have a question about combustion initiation.
If we create a fuel-air mixture and set it as reacting mixture, then we let it enter the combustion chamber, what's the condition to make it ignite? Sometimes I don't have combustion at all.
I am using propane air mixture(gas phase combustion), mass fraction for propane is 0.06(calculated from stoichiometric condition). Velocity is about 50m/s-100m/s, inlet temperature is 300k, the initial temperature in the combustion chamber is about 800k-1200k. Does this has something to do with the Arrhenius equation?
Thanks!
Old   November 10, 2004, 00:48
Default Re: What initiated combustion?
prashant S.S
hi! combustion of can combustor occurs ,when you patch a region/cells of your interest (for ignition),usually initial temperature of fuel nozzle is kept around 2000 k or mass flow of fuel is high to reach igntion temperature because of high turbulence. bye
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
Multiresolution + Turbulence + Combustion Raul Phoenics 1 March 31, 2005 08:51
