Multicomponent fluid
Old   October 8, 2004, 11:56
Default Multicomponent fluid
Andrea
Hi all...
I need set 2 different mixture in 2 different zone of the domain. I'm using CFX 4.4
In the first zone there is N2 (0.77 mass fraction) and O2 (0.23).
In the second zone there is H20 (0.6) and H2 (0.4).
I set N2 as background fluid.
At the second inlet I set O2 = 0.23 like boundary condition.
At the first inlet I set H20 =0.6 and H2 0.4 (so N2 =0)but run stop (error 65?)
If I set H20 = 1 the solver run.
The solver run only if H2 at the first inlet is bigger than 0.3 (error 65).
I develop a routine USRVIS e USRCND to update the gas property in the zone whitout N2.
Where is the mistake?
Thank for the help.
Andrea
PS I use the properties:
N2 background fluid HYD MFraction1 O2 MF2 WATER MF3
>>COMPRESSIBILITY PARAMETERS
FULLY COMPRESSIBLE
UNIVERSAL GAS CONSTANT 8.3140E+03
FLUID MOLECULAR WEIGHT 28.010E+00
REFERENCE PRESSURE 3.0390E+05
>>FLUID PARAMETERS
VISCOSITY 2.01E-5
>>HEAT TRANSFER PARAMETERS
THERMAL CONDUCTIVITY 0.2900E-01
FLUID SPECIFIC HEAT 1.00375E3
ENTHALPY REFERENCE TEMPERATURE 3.500E+02
>>MASS TRANSFER PARAMETERS
>>DIFFUSIVITIES
MASS FRACTIONS 3.83E-6 9.997E-7 1.07E-6
>>MOLECULAR WEIGHTS
MASS FRACTIONS 2.0160 3.199E+1 1.8E+01
>>SPECIFIC HEATS
HYD 1.434E+04
O2 0.93015E+3
WATER 2.0037E+3
Old   October 8, 2004, 15:15
Default Re: Multicomponent fluid
NymphadoraTonks
Post your full input file and the top part of the result file i.e. everthing except the calculation results.
Old   October 11, 2004, 05:12
Andrea
Thank you for the help. Andrea
INPUT FILE .fc
>>CFX4
:>OPTIONS
THREE DIMENSIONS
BODY FITTED GRID
CARTESIAN COORDINATES
POROUS FLOW
LAMINAR FLOW
HEAT TRANSFER
COMPRESSIBLE FLOW
STEADY STATE
MAXIMUM DEGREE OF POLYNOMIAL DEPENDENCE ON T 0
USER SCALAR EQUATIONS 6
MASS FRACTION EQUATIONS 3
>>USER FORTRAN
/* USRVIS*/
/* USRDIF
USRSRC*/ /* USRINT
USRCND */ /* USRCVG
USRBCS*/
>>VARIABLE NAMES
MASS FRACTION1 'HYD'
MASS FRACTION2 'O2'
MASS FRACTION3 'WATER'
USER SCALAR1 'USRDCC EREV'
USER SCALAR2 'USRDCC I'
USER SCALAR3 'USRDCC NACT'
USER SCALAR4 'USRDCC NMEM'
USER SCALAR5 'USRDCC PROVA'
USER SCALAR6 'USRDCC Q' /* USER SCALAR7 'USRDCC PROVA'*/
/* USER SCALAR1 'MASS RESIDUAL'*/
#CALC
KOST=1.29E-4;
I=1E4;
AMEA=2.5E-3;
ACH=1E-6;
T=353;
P=3*1E5;
XW=0.6;
XH=1-XW;
XO=0.23;
V_H=KOST*I*AMEA*T/(ACH*XH*P);
V_O=KOST/2*I*AMEA*T/(ACH*XO*P); #ENDCALC
>>MODEL TOPOLOGY
:>MODIFY PATCH
OLD PATCH NAME 'SOLCON_GRAF'
NEW PATCH GROUP NUMBER 1
:>MODIFY PATCH
OLD PATCH NAME 'SOLCON_MEMB'
NEW PATCH GROUP NUMBER 2
>>MODEL DATA
/* >>RHIE CHOW SWITCH
MODIFIED RESISTANCE TREATMENT
RECTANGULAR VELOCITY CORRECTIONS*/
:>TITLE
PROBLEM TITLE 'INTRODUCTORY EXAMPLE 1'
:>PHYSICAL PROPERTIES
>>SOLID HEAT TRANSFER PARAMETERS
PATCH GROUP NUMBER 1 SCALAR CONDUCTIVITY 150.6
:>SOLID HEAT TRANSFER PARAMETERS
PATCH GROUP NUMBER 2 SCALAR CONDUCTIVITY 0.455
FULLY COMPRESSIBLE
>>FLUID PARAMETERS
VISCOSITY 2.01E-5
>>POROUS REGION PARAMETERS
VOLUME POROSITY 4.0000E-01
>>DIFFUSIVITIES
>>MOLECULAR WEIGHTS
>>SPECIFIC HEATS
HYD 1.434E+04
O2 0.93015E+3
WATER 2.0037E+3
>>SOLVER DATA
:>PROGRAM CONTROL
MAXIMUM NUMBER OF ITERATIONS 2000
MASS SOURCE TOLERANCE 5.0000E-10
:>MODEL BOUNDARY CONDITIONS
:>PRESSURE BOUNDARIES
PATCH NAME 'PRESS'
PRESSURE 0.0000E+00
>>INLET BOUNDARIES
PATCH NAME 'INLET_H'
NORMAL VELOCITY #V_H
TEMPERATURE 353
HYD 0.4 /* HYD #XH*/ /* WATER #XW*/ /* WATER 0.7*/ /* O2 1*/
>>INLET BOUNDARIES
PATCH NAME 'INLET_O'
NORMAL VELOCITY #V_O
TEMPERATURE 353
/*WATER #XW*/
O2 #XO
/* >>WALL BOUNDARIES
PATCH NAME 'WALL_D'
TEMPERATURE 3.5300E+02
>>WALL BOUNDARIES
PATCH NAME 'WALL_TOP'
TEMPERATURE 3.5300E+02 */
/*>>OUTPUT OPTIONS
:>INTERMEDIATE RESTART FILES
ITERATION INTERVAL 100*/
:>STOP
************************************************** ***** OUTPUT FILE .fo ************************************************** *****
131 1 10 7 7 HIGH K 2 1 WALL WALL_TOP
9 1 10 1 10 1 1 LOW K 5 1 WALL WALL_TOP
10 1 10 1 131 1 1 LOW K 6 1 WALL WALL_TOP
11 1 10 131 131 1 7 HIGH J 1 1 WALL WALL
12 1 1 1 131 1 7 LOW I 1 1 WALL WALL
13 10 10 1 9 1 7 HIGH I 1 2 WALL CONDUCTING WALL
14 10 10 10 128 1 7 HIGH I 1 1 WALL WALL
15 1 131 1 1 1 7 LOW J 2 1 WALL WALL
16 1 9 10 10 1 7 HIGH J 2 2 WALL CONDUCTING WALL
17 10 128 10 10 1 7 HIGH J 2 1 WALL WALL
18 131 131 1 10 1 7 HIGH I 2 1 WALL WALL
19 4 10 1 10 1 1 LOW K 3 1 WALL WALL
20 4 10 1 1 1 7 LOW J 3 1 WALL WALL
21 4 10 10 10 1 7 HIGH J 3 1 WALL WALL
22 1 1 1 10 1 7 LOW I 3 1 WALL WALL
23 10 10 1 10 1 7 HIGH I 3 2 WALL CONDUCTING WALL
24 1 10 131 131 1 7 HIGH J 4 1 WALL WALL
25 1 1 1 9 1 7 LOW I 4 2 WALL CONDUCTING WALL
26 1 1 10 128 1 7 LOW I 4 1 WALL WALL
27 10 10 1 131 1 7 HIGH I 4 1 WALL WALL
28 4 10 1 10 7 7 HIGH K 5 1 WALL WALL
29 4 10 1 1 1 7 LOW J 5 1 WALL WALL
30 4 10 10 10 1 7 HIGH J 5 1 WALL WALL
31 1 1 1 10 1 7 LOW I 5 1 WALL WALL
32 10 10 1 10 1 7 HIGH I 5 2 WALL CONDUCTING WALL
33 1 10 131 131 1 7 HIGH J 6 1 WALL WALL
34 1 1 1 9 1 7 LOW I 6 2 WALL CONDUCTING WALL
35 1 1 10 128 1 7 LOW I 6 1 WALL WALL
36 10 10 1 131 1 7 HIGH I 6 1 WALL WALL
37 1 5 1 131 1 1 LOW K 7 1 WALL WALL
38 16 25 1 9 1 1 LOW K 7 2 WALL CONDUCTING WALL
39 36 40 1 131 1 1 LOW K 7 1 WALL WALL
40 16 25 10 128 1 1 LOW K 7 1 WALL WALL
41 1 40 1 1 1 6 LOW J 7 1 WALL WALL
42 1 40 131 131 1 6 HIGH J 7 1 WALL WALL
43 1 1 1 131 1 6 LOW I 7 1 WALL WALL
44 40 40 1 131 1 6 HIGH I 7 1 WALL WALL
45 1 40 1 131 1 1 HIGH K 8 2 WALL CONDUCTING WALL
46 1 40 1 1 1 1 LOW J 8 1 WALL WALL
47 1 40 131 131 1 1 HIGH J 8 1 WALL WALL
48 1 1 1 131 1 1 LOW I 8 1 WALL WALL
49 40 40 1 131 1 1 HIGH I 8 1 WALL WALL
50 1 40 1 131 1 1 LOW K 10 2 WALL CONDUCTING WALL
51 1 40 1 1 1 1 LOW J 10 1 WALL WALL
52 1 40 131 131 1 1 HIGH J 10 1 WALL WALL
53 1 1 1 131 1 1 LOW I 10 1 WALL WALL
54 40 40 1 131 1 1 HIGH I 10 1 WALL WALL
55 1 5 1 131 6 6 HIGH K 11 1 WALL WALL
56 16 25 1 9 6 6 HIGH K 11 2 WALL CONDUCTING WALL
57 36 40 1 131 6 6 HIGH K 11 1 WALL WALL
58 16 25 10 128 6 6 HIGH K 11 1 WALL WALL
59 1 40 1 1 1 6 LOW J 11 1 WALL WALL
60 1 40 131 131 1 6 HIGH J 11 1 WALL WALL
61 1 1 1 131 1 6 LOW I 11 1 WALL WALL
62 40 40 1 131 1 6 HIGH I 11 1 WALL WALL
63 1 40 1 1 1 3 LOW J 9 1 CNDBDY CNDBDY
64 1 40 131 131 1 3 HIGH J 9 1 CNDBDY CNDBDY
65 1 1 1 131 1 3 LOW I 9 1 CNDBDY CNDBDY
66 40 40 1 131 1 3 HIGH I 9 1 CNDBDY CNDBDY
67 1 10 10 126 1 1 LOW K 12 1 CNDBDY CNDBDY
68 1 10 1 126 7 7 HIGH K 12 1 CNDBDY CNDBDY
69 1 10 1 1 1 7 LOW J 12 1 CNDBDY CNDBDY
70 1 1 10 126 1 7 LOW I 12 1 CNDBDY CNDBDY
71 10 10 10 126 1 7 HIGH I 12 1 CNDBDY CNDBDY
72 1 10 1 126 1 1 LOW K 13 1 CNDBDY CNDBDY
73 1 10 10 126 7 7 HIGH K 13 1 CNDBDY CNDBDY
74 1 10 1 1 1 7 LOW J 13 1 CNDBDY CNDBDY
75 1 1 10 126 1 7 LOW I 13 1 CNDBDY CNDBDY
76 10 10 10 126 1 7 HIGH I 13 1 CNDBDY CNDBDY
77 10 10 1 9 1 7 HIGH I 1 1 BLKBDY GLUE-PATCH----1HIGH-I-BLK----1
78 1 1 1 9 1 7 LOW I 12 1 BLKBDY GLUE-PATCH----2LOW--I-BLK---12
79 10 10 129 131 1 7 HIGH I 1 1 BLKBDY GLUE-PATCH----3HIGH-I-BLK----1
80 1 3 1 1 1 7 LOW J 3 1 BLKBDY GLUE-PATCH----4LOW--J-BLK----3
81 1 10 1 131 1 1 LOW K 1 1 BLKBDY GLUE-PATCH----5LOW--K-BLK----1
82 6 15 1 131 6 6 HIGH K 11 1 BLKBDY GLUE-PATCH----6HIGH-K-BLK---11
83 1 9 10 10 1 7 HIGH J 2 1 BLKBDY GLUE-PATCH----7HIGH-J-BLK----2
84 1 1 1 9 1 7 LOW I 13 1 BLKBDY GLUE-PATCH----8LOW--I-BLK---13
85 129 131 10 10 1 7 HIGH J 2 1 BLKBDY GLUE-PATCH----9HIGH-J-BLK----2
86 1 3 1 1 1 7 LOW J 5 1 BLKBDY GLUE-PATCH---10LOW--J-BLK----5
87 1 131 1 10 1 1 LOW K 2 1 BLKBDY GLUE-PATCH---11LOW--K-BLK----2
88 6 15 1 131 1 1 LOW K 7 1 BLKBDY GLUE-PATCH---12LOW--K-BLK----7
89 10 10 1 10 1 7 HIGH I 3 1 BLKBDY GLUE-PATCH---13HIGH-I-BLK----3
90 1 10 126 126 1 7 HIGH J 12 1 BLKBDY GLUE-PATCH---14HIGH-J-BLK---12
91 1 3 10 10 1 7 HIGH J 3 1 BLKBDY GLUE-PATCH---15HIGH-J-BLK----3
92 1 1 129 131 1 7 LOW I 4 1 BLKBDY GLUE-PATCH---16LOW--I-BLK----4
93 1 3 1 10 1 1 LOW K 3 1 BLKBDY GLUE-PATCH---17LOW--K-BLK----3
94 16 25 129 131 6 6 HIGH K 11 1 BLKBDY GLUE-PATCH---18HIGH-K-BLK---11
95 1 1 1 9 1 7 LOW I 4 1 BLKBDY GLUE-PATCH---19LOW--I-BLK----4
96 10 10 1 9 1 7 HIGH I 12 1 BLKBDY GLUE-PATCH---20HIGH-I-BLK---12
97 1 10 1 131 1 1 LOW K 4 1 BLKBDY GLUE-PATCH---21LOW--K-BLK----4
98 26 35 1 131 6 6 HIGH K 11 1 BLKBDY GLUE-PATCH---22HIGH-K-BLK---11
99 10 10 1 10 1 7 HIGH I 5 1 BLKBDY GLUE-PATCH---23HIGH-I-BLK----5
100 1 10 126 126 1 7 HIGH J 13 1 BLKBDY GLUE-PATCH---24HIGH-J-BLK---13
101 1 3 10 10 1 7 HIGH J 5 1 BLKBDY GLUE-PATCH---25HIGH-J-BLK----5
102 1 1 129 131 1 7 LOW I 6 1 BLKBDY GLUE-PATCH---26LOW--I-BLK----6
103 1 3 1 10 7 7 HIGH K 5 1 BLKBDY GLUE-PATCH---27HIGH-K-BLK----5
104 16 25 129 131 1 1 LOW K 7 1 BLKBDY GLUE-PATCH---28LOW--K-BLK----7
105 1 10 1 131 7 7 HIGH K 6 1 BLKBDY GLUE-PATCH---29HIGH-K-BLK----6
106 26 35 1 131 1 1 LOW K 7 1 BLKBDY GLUE-PATCH---30LOW--K-BLK----7
107 1 1 1 9 1 7 LOW I 6 1 BLKBDY GLUE-PATCH---31LOW--I-BLK----6
108 10 10 1 9 1 7 HIGH I 13 1 BLKBDY GLUE-PATCH---32HIGH-I-BLK---13
109 1 40 1 131 6 6 HIGH K 7 1 BLKBDY GLUE-PATCH---33HIGH-K-BLK----7
110 1 40 1 131 1 1 LOW K 8 1 BLKBDY GLUE-PATCH---34LOW--K-BLK----8
111 16 25 1 9 1 1 LOW K 7 1 BLKBDY GLUE-PATCH---35LOW--K-BLK----7
112 1 10 1 9 7 7 HIGH K 13 1 BLKBDY GLUE-PATCH---36HIGH-K-BLK---13
113 1 40 1 131 1 1 HIGH K 8 1 BLKBDY GLUE-PATCH---37HIGH-K-BLK----8
114 1 40 1 131 1 1 LOW K 9 1 BLKBDY GLUE-PATCH---38LOW--K-BLK----9
115 1 40 1 131 3 3 HIGH K 9 1 BLKBDY GLUE-PATCH---39HIGH-K-BLK----9
116 1 40 1 131 1 1 LOW K 10 1 BLKBDY GLUE-PATCH---40LOW--K-BLK---10
117 1 40 1 131 1 1 HIGH K 10 1 BLKBDY GLUE-PATCH---41HIGH-K-BLK---10
118 1 40 1 131 1 1 LOW K 11 1 BLKBDY GLUE-PATCH---42LOW--K-BLK---11
119 16 25 1 9 6 6 HIGH K 11 1 BLKBDY GLUE-PATCH---43HIGH-K-BLK---11
120 1 10 1 9 1 1 LOW K 12 1 BLKBDY GLUE-PATCH---44LOW--K-BLK---12
121 1 10 1 126 1 7 12 1 SOLCON SOLCON_GRAF
122 1 10 1 126 1 7 13 1 SOLCON SOLCON_GRAF
123 1 40 1 131 1 3 9 2 SOLCON SOLCON_MEMB
124 1 40 1 131 1 6 7 1 POROUS POROUS
125 1 40 1 131 1 1 8 1 POROUS POROUS
126 1 40 1 131 1 1 10 1 POROUS POROUS
127 1 40 1 131 1 6 11 1 POROUS POROUS
128 1 10 1 131 1 7 1 1 USER3D USER3D_A
129 1 10 1 10 1 7 3 1 USER3D USER3D_A
130 1 10 1 131 1 7 4 1 USER3D USER3D_A
131 1 40 1 131 1 1 10 1 USER3D USER3D_A
132 1 40 1 131 1 6 11 1 USER3D USER3D_A
133 1 131 1 10 1 7 2 1 USER3D USER3D_C
134 1 10 1 10 1 7 5 1 USER3D USER3D_C
135 1 10 1 131 1 7 6 1 USER3D USER3D_C
136 1 40 1 131 1 6 7 1 USER3D USER3D_C
137 1 40 1 131 1 1 8 1 USER3D USER3D_C
138 1 10 1 131 1 7 1 1 USER3D USER3D_CHA
139 1 10 1 10 1 7 3 1 USER3D USER3D_CHA
140 1 10 1 131 1 7 4 1 USER3D USER3D_CHA
141 1 131 1 10 1 7 2 1 USER3D USER3D_CHC
142 1 10 1 10 1 7 5 1 USER3D USER3D_CHC
143 1 10 1 131 1 7 6 1 USER3D USER3D_CHC
144 1 40 1 131 1 1 10 1 USER3D USER3D_CLA
145 1 40 1 131 1 1 8 1 USER3D USER3D_CLC
146 1 40 1 131 1 1 10 1 USER3D USER3D_ME_A
147 1 40 1 131 1 6 11 1 USER3D USER3D_ME_A
148 1 40 1 131 1 6 7 1 USER3D USER3D_ME_C
149 1 40 1 131 1 1 8 1 USER3D USER3D_ME_C
NO. OF INTERBLOCK BOUNDARIES = 22
INTER-BLOCK BOUNDARY NO. 1 1ST. PATCH NAME = GLUE-PATCH----1HIGH-I-BLK----1 2ND. PATCH NAME = GLUE-PATCH----2LOW--I-BLK---12 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 2 1ST. PATCH NAME = GLUE-PATCH----3HIGH-I-BLK----1 2ND. PATCH NAME = GLUE-PATCH----4LOW--J-BLK----3 ORIENTATION CHANGE = HIGH J LOW I HIGH K
INTER-BLOCK BOUNDARY NO. 3 1ST. PATCH NAME = GLUE-PATCH----5LOW--K-BLK----1 2ND. PATCH NAME = GLUE-PATCH----6HIGH-K-BLK---11 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 4 1ST. PATCH NAME = GLUE-PATCH----7HIGH-J-BLK----2 2ND. PATCH NAME = GLUE-PATCH----8LOW--I-BLK---13 ORIENTATION CHANGE = HIGH J HIGH I LOW K
INTER-BLOCK BOUNDARY NO. 5 1ST. PATCH NAME = GLUE-PATCH----9HIGH-J-BLK----2 2ND. PATCH NAME = GLUE-PATCH---10LOW--J-BLK----5 ORIENTATION CHANGE = LOW I HIGH J LOW K
INTER-BLOCK BOUNDARY NO. 6 1ST. PATCH NAME = GLUE-PATCH---11LOW--K-BLK----2 2ND. PATCH NAME = GLUE-PATCH---12LOW--K-BLK----7 ORIENTATION CHANGE = HIGH J HIGH I LOW K
INTER-BLOCK BOUNDARY NO. 7 1ST. PATCH NAME = GLUE-PATCH---13HIGH-I-BLK----3 2ND. PATCH NAME = GLUE-PATCH---14HIGH-J-BLK---12 ORIENTATION CHANGE = LOW J HIGH I HIGH K
INTER-BLOCK BOUNDARY NO. 8 1ST. PATCH NAME = GLUE-PATCH---15HIGH-J-BLK----3 2ND. PATCH NAME = GLUE-PATCH---16LOW--I-BLK----4 ORIENTATION CHANGE = LOW J HIGH I HIGH K
INTER-BLOCK BOUNDARY NO. 9 1ST. PATCH NAME = GLUE-PATCH---17LOW--K-BLK----3 2ND. PATCH NAME = GLUE-PATCH---18HIGH-K-BLK---11 ORIENTATION CHANGE = LOW J HIGH I HIGH K
INTER-BLOCK BOUNDARY NO. 10 1ST. PATCH NAME = GLUE-PATCH---19LOW--I-BLK----4 2ND. PATCH NAME = GLUE-PATCH---20HIGH-I-BLK---12 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 11 1ST. PATCH NAME = GLUE-PATCH---21LOW--K-BLK----4 2ND. PATCH NAME = GLUE-PATCH---22HIGH-K-BLK---11 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 12 1ST. PATCH NAME = GLUE-PATCH---23HIGH-I-BLK----5 2ND. PATCH NAME = GLUE-PATCH---24HIGH-J-BLK---13 ORIENTATION CHANGE = LOW J HIGH I HIGH K
INTER-BLOCK BOUNDARY NO. 13 1ST. PATCH NAME = GLUE-PATCH---25HIGH-J-BLK----5 2ND. PATCH NAME = GLUE-PATCH---26LOW--I-BLK----6 ORIENTATION CHANGE = LOW J HIGH I HIGH K
INTER-BLOCK BOUNDARY NO. 14 1ST. PATCH NAME = GLUE-PATCH---27HIGH-K-BLK----5 2ND. PATCH NAME = GLUE-PATCH---28LOW--K-BLK----7 ORIENTATION CHANGE = LOW J HIGH I HIGH K
INTER-BLOCK BOUNDARY NO. 15 1ST. PATCH NAME = GLUE-PATCH---29HIGH-K-BLK----6 2ND. PATCH NAME = GLUE-PATCH---30LOW--K-BLK----7 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 16 1ST. PATCH NAME = GLUE-PATCH---31LOW--I-BLK----6 2ND. PATCH NAME = GLUE-PATCH---32HIGH-I-BLK---13 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 17 1ST. PATCH NAME = GLUE-PATCH---33HIGH-K-BLK----7 2ND. PATCH NAME = GLUE-PATCH---34LOW--K-BLK----8 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 18 1ST. PATCH NAME = GLUE-PATCH---35LOW--K-BLK----7 2ND. PATCH NAME = GLUE-PATCH---36HIGH-K-BLK---13 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 19 1ST. PATCH NAME = GLUE-PATCH---37HIGH-K-BLK----8 2ND. PATCH NAME = GLUE-PATCH---38LOW--K-BLK----9 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 20 1ST. PATCH NAME = GLUE-PATCH---39HIGH-K-BLK----9 2ND. PATCH NAME = GLUE-PATCH---40LOW--K-BLK---10 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 21 1ST. PATCH NAME = GLUE-PATCH---41HIGH-K-BLK---10 2ND. PATCH NAME = GLUE-PATCH---42LOW--K-BLK---11 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
INTER-BLOCK BOUNDARY NO. 22 1ST. PATCH NAME = GLUE-PATCH---43HIGH-K-BLK---11 2ND. PATCH NAME = GLUE-PATCH---44LOW--K-BLK---12 ORIENTATION CHANGE = HIGH I HIGH J HIGH K
SUMMARY OF GRID QUALITY
MAX VALUE MIN VALUE
ORTHOG. DEVIATION 5.34E+00 2.50E-06
GRID EXPANSION 2.67E+00 1.03E+00
CELL VOLUME 1.38E-11 2.86E-13
SKEW RATIO 1.04E+00 1.00E+00
TWIST ANGLE 5.71E+00 0.00E+00
TAPER RATIO 1.08E+00 1.00E+00
REAL BOUNDARY CONDITIONS
*** ALL WALLS HAVE DEFAULT BOUNDARY CONDITIONS ***
*** OF ZERO VELOCITY ***
*** AND ZERO HEAT FLUX ***
*** ALL CONDUCTING BOUNDARIES HAVE DEFAULT BOUNDARY CONDITIONS ***
*** OF ZERO HEAT FLUX ***
CFX-4.4 finished on Mon Oct 11 10:06:08 2004
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Multicomponent Fluid Mehul CFX 2 June 30, 2008 12:26
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
