September 25, 2018, 05:06 |
Recirculation in Rotor Domain
Rep Power: 14 |
Hi
I have posted about this recirculation previously as well. Now I have a doubt, I am running a steady state Rotor-Stator configuration simulation and I increased the outflow region to 10times the rotor diameter and still I could see huge recirculation after the step as shown in the image. Can someone tell me if this is physical or could there be something wrong in my computation ? And will this recirculation affect my rotor performance and simulation as well ? Or should I do transient simulation ? |
September 25, 2018, 05:20 |
Gert-Jan
Rep Power: 27 |
It is common practice to put the outlet outside the recirculation. So it should be put further downstream.
And is it realistic? I have no reason to doubt on these results. I would advise to go outside on a windy day and find out yourself if the windspeed is much lower behind a building ;-) Will it affect your results? It depends on what question you are trying to answer using CFD. Is it the efficiency of your rotor? Then I doubt if you will see any effect. But you should determine that yourself. Put the outlet further away and determine the result. |
September 25, 2018, 05:59 |
Rep Power: 14 |
Hi Gert JAn
Yes its all about calculating the power from the rotor. And I was thinking if the rotor gets some negative velocity due to this recirculation and then it will affect the power. But as I run it longer the recirculation diameter changes or moving .So I am not sure how to quantify it. This I can see only in a transient simulation right ? This I ran for 3000 iterations so I will use this as a restart for unsteady simulation. Will that be ok ? |
September 25, 2018, 06:11 |
Rep Power: 143 |
The magnitude of these effects vary simulation to simulation so you will have to do a sensitivity study as Gert-Jan recommends to determine how important it is in your case.
Yes, you can use a steady state simulation (even a partly converged one) as an initial condition for transient simulations. This is providing you don't care about the startup transient, only the periodic pseudo-steady state conditions are of interest to you.
what is difference between recirculation region, eddy field and vortex? | fruitkiwi | Main CFD Forum | 14 | January 1, 2021 13:43 |
recirculation inlet | hashim13 | FLUENT | 0 | March 4, 2017 02:36 |
[OpenFOAM] How can I compute the area of recirculation zone in pitzDaily | invadoria | ParaView | 1 | December 28, 2016 11:00 |
Calculation of gas recirculation ratio in MILD/flameless combustion? | lem | ANSYS | 0 | December 22, 2016 18:58 |
Plotting recirculation zone in CFD Post | ashtonJ | CFX | 0 | April 30, 2011 20:31 |
