Transient Results
Old   November 26, 2004, 11:00
Default Transient Results
Ogbeni
Hello All, I need some explanation on obtaining transient results fron CFX5. I had completed a transient simulation and tried to export it to fieldview, but to my astonishment only the last state was present. Should I have requested a minimal result at some time interval with defined variables ? or full ? I will appreciate if some one can help to understand how to obtain a comprehensive result over the entire time period.
Old   November 26, 2004, 12:22
Default Re: Transient Results
jon
You need to specify Transient results in Output Options. You can choose timesetep list or interval.
You can choose minimal or full results.
You can have a mixture of either the above options.
Old   November 26, 2004, 12:34
Rui
Hi
In CFX-Pre, Output Control, you have to create Transient Results (as many as you want). You may chose the option minimal and define the variables you want, or the option full. You may also chose between the options time interval (the results files will be created at every interval) or time list ( the results files will be created at each time instant of the list).
I use to create transient results: 1- with the most important variables, with a small time interval; 2- with the option full, with a larger time interval; and 3- with the option full at some time instants I consider important.
If your simulations take a long time to complete, it is also advisable to create backup results with the option full, so you may restart your simulation at the last backup, if for some reason your computer crashes or the power shuts down.
At the manual you will find further information about the Output Control possibilities. Also, take a look at the tutorials with transient simulations.
Regards,
Rui
Old   November 30, 2004, 06:09
Roe
CFX will NOT export minimal transient result files to FV. You must use the 'full' option in 'Transient Results'
Old   November 30, 2004, 07:10
Ogbeni
Hello Roe, Does tha mean I must indicate several time steps under the full option ? it seems that the full option gives only the last tine step.
Old   November 30, 2004, 09:43
Roe
'Fraid so. Say your solution timestep is 1e-3 seconds, to get a result file every 10 timesteps you must set your 'Time Interval' on the 'Transient Results' tab to be 1e-2 seconds. Alternatively you can specify exact times to write a transient result file under the 'Time List' option. These files will appear as *.trn in the run time directory (*.dir). For the export to FV to work correctly, you must have the 'Full' option selected. You don't need to output boundary flows or equation residuals.
Time averaging results from a transient run Flow Squad CFX 4 October 24, 2011 09:11
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Combining Transient results after a backup Dre CFX 9 February 18, 2008 08:43
intermediate results during a transient run Michael Skoblin CFX 1 September 25, 2006 14:00
Minimal transient result lokks like full in Post Korsh Mik CFX 14 July 19, 2005 02:45
