October 18, 2018, 14:40 |
Cfx
amin malmir
Hi.
I want to simulate a marine propeller in cfx. I have heard there are three ways to do. First one: using of one cylinderical domain that is constant and the propeller is rotating. Second: two cylinderical domain that the smaller one is rotating and the bigger is constant. Third : the propeller is constant and one cylinder is rotating. Am i right? |
October 18, 2018, 17:47 |
Rep Power: 143 |
I do not understand what you are proposing. If you are modelling a spinning propeller then you need to spin it somehow. The easiest way to do this is with a rotation frame of reference, so the propeller needs to be in a rotating frame of reference. The only choice is whether you have a stationary frame of reference around it, which you would use to model things which are not rotating like the ship hull or free surface.
cfx & fluent |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
High Resolution (CFX) vs 2nd Order Upwind (Fluent) | gravis | ANSYS | 3 | March 24, 2011 02:43 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
FSI using CFX and ANSYS | Bi Chang | CFX | 2 | May 10, 2005 04:47 |
