heat release /without cpombustion model
Old   February 24, 2005, 17:25
Default heat release /without cpombustion model
rosilva
Hello everybody,
I have to model a kerosene pool fire and as kerosene/crude oil material and reactions are not avalibale in the library i would rather prefere to model the fire as a heat release of lets say 10 MW.
Do you Know how i can set this in Cfx 5.7? I know it was possible to do it in CFX 4, but in 5.7 i dont know how to do it.
Can you give me some advices? Thanks, Rosilva
Old   March 9, 2005, 06:53
Default Re: heat release /without cpombustion model
ulian
Hello Rosilva,
If you are not interested in species concentrations, you could also use any other fuel as a combusting material (CH4, for example). You just have to make sure that the HRR is the correct one. To model this, you could release fuel (CH4) from an inlet with the shape of your pool fire.
You could also look at the CFX tutorials (Reacting flow in a mixing tube), how you could set up a reaction by yourself if you are interested in species concentration.
Alternatively, you could also use a simple heat release source model, but be carefull to adjust the volume of the heat source, so that you get reasonable temperatures.
I hope that this helps a bit.
Best wishes, Ulian
heat transfer with s2s radiation model in fluent D. L. FLUENT 3 July 31, 2008 07:40
heat exchanger model jack FLUENT 3 July 25, 2008 04:26
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
HELP needed. Species transport with heat release!! Amr FLUENT 0 May 27, 2006 15:41
How to use Heat Exchanger model? Johnny FLUENT 0 August 9, 2004 07:44
