Node values problems
Old   March 10, 2005, 09:08
Default Node values problems
Kiddo
I do a transient conduction analysis(about 200 run steps and residual target is 1E-4). There're two domains, inner and outer.(the inner one is fully inside the outer one)and the mesh nodes are fully matched at interface(created by ICEM_CFD simultaneously). I export both the domains' temperature data and I found that the temperature at interface nodes are slightly different in different domain!For example: for inner domain x1,y1,z1 359.4359 DegC . . for outer domain x1,y1,z1 359.4285 DegC (note: same coordinate) The temperature should be same for the same node in different domain, right? Thanks for response.
Old   March 10, 2005, 15:56
Default Re: Node values problems
I suspect the small difference is caused by convergence, and as your simulation converges tighter the difference will get smaller.
Old   March 10, 2005, 19:47
Kiddo
Hi Glenn Horrocks, thanks, I do the following trial run cases for the same definition file: 1. parallel run, Converge Target.=1e-4 2. serial run, Converge Target.=1e-4 3. parallel run, Converge Target.=1e-5 4. serial run, Converge Target.=1e-5 (also run transient and steady case for above cases) and found that 1. It doesn't matter with transient or steady. 2. It doesn't matter with the parallel or serial run 3. It always got a slightly difference for the node value at interface node in different domain. And found also the Converge Target affect the result no very apparently. I know CFX is by Finite Volume Method which is a special case of Finite Element Method. Is it possible due to the FVM natively?
Old   March 11, 2005, 00:02
Juan Carlos
The values are supposed to be different unless the problem is isothermal..
Either node does not represent the value at the boundary, but the mean value of the finite volume (or half volume to be precise) it represents. The smaller the finite volume (finer mesh) the closer these 2 values will be..
Hope this helps, JC.
Old   March 11, 2005, 01:08
Kiddo
Hi Juan Carlos, thanks, I refine the interface mesh by 4 times (and it's very dense now). I re-run it and I found that the difference is almost the same as previous mesh.
Old   March 11, 2005, 13:37
Rui
Hi, If the temperature gradient is perpendicular to the interface, you have to refine the mesh in that direction for those 2 values become closer.
Depending on how you are creating the volume mesh, refining the surface mesh at the interface may lead or not to a finer volume mesh on the direction perpendicular to the interface.
Regards,
Rui
Old   March 11, 2005, 21:44
Kiddo
Thanks, but maybe the mesh size is not the key point. I create a new simple geometry just for test only. Even I refine the volume size globally 5 times and compare the results. The difference is almost the same. I'm wondering there's something inside the solver theroey which affects the node value's difference. Thanks for response again. -Kiddo
Old   March 12, 2005, 05:43
Alex
maybe this page can help you CFX-post workspace pag 29: hybrid and conservative variable values
Old   March 13, 2005, 19:29
Kiddo
Hi,Alex , I got it ! that's the key point. Thanks!!!!!!!!!!! The reason is described in Solver Theorey-Numerical Discretisation p. 228 Alex, thanks again!
Old   March 13, 2005, 19:41
Kiddo
Hi, Juan Carlos: After Alex reminds me seeing the Solver Theorey, and I found you are right . The reason why I cannot get closer difference after refining mesh may be due to the inner domain has a subdomain with a heat source assigned. So there'll be always a gradient over it.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 16:24
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
Values of k and e for multiphase problems!! zack FLUENT 0 January 28, 2006 02:16
Node values on UDF??? Kamal FLUENT 1 December 10, 1999 10:37
