Transient calculation - BC Profils and MassFlowRate |
November 24, 2011, 12:14 |
Rep Power: 14 |
Hey together,
I really have I big problem with my calculation ..... I want to simulate a channel of a two-pass cooling system. My investigations are only on the inlet-channel. And I want to comapre the experimental results with my numerical results. But the problem is the folowing: I need: - Velocity Profil (fully developed) at the Inlet (there is an extra channel in the experiment, but I don't want to simualte this one too -> lots of cells and CPU-time) - MassFlowRate at the Inlet (time variant from experimental datas) - Temperature at the Inlet (time variant from experimental datas) - Temperature Profil at the Inlet (fully developed) The Temperature part is not really the problem. I did a periodic calculation and got values for Temperature/massFlowAve(Temperature)@INLET. Exportet these datas as BC. Importet the datas to CFX-Pre. And my Boundary at the Inlet is now the value from BC * Temperature (t). But how can I do the other two Boundary conditions? I tried to create a new variable (name it AVM) from the periodic results (Velocity/massflow) and added as Inlet condition MassflowRate: massflow(t) and direction x=0 y=AVM z=0 (my flow direction is y). But the I get values greater 0 at the wall. Hope you guys can help me. Thanks in advance. |
