Drag coefficient in ANSYS\Flotran
Old   April 13, 2005, 18:40
Default Drag coefficient in ANSYS\Flotran
Tamanoir
Hello!
I am simulating flow over a cylinder and want to get drag coefficient at various reynolds numbers. I modelled 2-D cylinder by making a circular hole in a rectangle and applied no slip boundary condition over the spherical hole. Also I applied velocity inlet and pressure outlet boundary condition. Now the problem is I am getting drag coefficient with a deviation of 20-40% from the experimental results. For example, I am getting Cd = 0.6 at Re = 1000, which should be 1 according to experimental results. I used standard k-e turbulence model.
Please help.
Old   April 13, 2005, 18:43
Default Re: Drag coefficient in ANSYS\Flotran
Tamanoir
I read all messages posted earlier.But I didn`t found the answer for this question.
Old   April 14, 2005, 04:26
phonewell
maybe Cd=0.9~1.1 is a better choice.
Old   April 16, 2005, 11:46
Derrek
What kind of convergence are you getting? PRES in particular? Also, check the mass balance in the pfl file. There should be a very small difference (if at all) between the inlet and outlet.
Cheers,
Derrek
Drag Coefficient Convergence Problem John FLUENT 18 June 24, 2023 09:22
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 00:49
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
