April 6, 2005, 06:50 |
ICEM 5.1 to CFX Prism Element
Hi all, I have a query regarding ICEM 5.1. I created a 2-D mesh Tri-Mesh on one face of 3-D geometry. I want to extrude that elements in 3-D. I used extrude command to do it. Now when i transfer mesh to CFX it says it cannot transfer because of no volume element defined in 3-D region. I want 2-D mesh extruded in 3-D or form a prism element. I dont know how to make prism and assign the boundary conditions again. Please help. many thanks, ashish
April 6, 2005, 18:32 |
Re: ICEM 5.1 to CFX Prism Element
To generate 2D extruded meshes for CFX5 in ICEM 5.1, you need to: 1) Generate a surface mesh on the face you wish to extrude. If you have had to generate this mesh from the surface mesh on a 3D body then delete the meshes on the other surfaces. Also make sure you delete the volume elements, if you have any. 2) Extrude the elements by either a translation or rotation. Put the volume elements, side elements and top elements in different families. 3) Manually put the side elements in new families for your boundary patches. Glenn Horrocks |
definition of "node" / "element" in CFX and ICEM CFD | murx | CFX | 5 | January 18, 2017 03:24 |
strange mesh points after importing from icem to cfx | cibo | ANSYS | 6 | February 8, 2012 16:43 |
[ICEM] Node Number vs. Node_ID & ICEM vs. CFX | Araz | ANSYS Meshing & Geometry | 1 | April 25, 2011 11:03 |
how to export icem mesh to cfx? | Michael | CFX | 1 | May 3, 2008 13:35 |
Error Converting ICEM Structured Mesh to CFX | Chebeba | CFX | 11 | October 5, 2006 08:05 |
