monitor areAve for a plane in solver
Old   April 7, 2005, 18:10
Default monitor areAve for a plane in solver
caty
Hi everybody!
I need to monitor the average temperature on a plane in the solver. But from Pre I noticed that is it posible only to use the areAve function only for the boundary conditions and domains created. My plane is not definded in Pre.
Any ideas? caty
Old   April 7, 2005, 19:08
Default Re: monitor areAve for a plane in solver
To do it in the solver you have to define some sort of boundary patch at that point. If you split your mesh at that plane and join it with a 1:1 interface you can do calculations on the interface. Note it will slightly increase your simulation time but for a 1:1 interface the increase is very small.
Alternately you can do it in CFX-Post in post-processing.
Old   April 8, 2005, 06:44
caty
How can I split the mesh?? Only in the meshing software or i can do it in Pre as well?
Old   April 10, 2005, 18:41
Splitting the mesh must be done in the meshing software. CFX-Pre cannot do anything with the mesh, except simple transformations such as translations, scaling, rotations.
Regards, Glenn Horrocks
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 07:16
